-   -   Wallpaper on Plywood - 30 yrs old - paint or paper (http://www.diychatroom.com/f4/wallpaper-plywood-30-yrs-old-paint-paper-172683/)
joeybl 02-22-2013 09:04 PM
Similar to previous post, I have vinyl wallpaper on plywood that has been there for 30 years (some less). Would painted plywood really look any better than painted wallpaper? Some of it has satin grain finish that I wouldn't mind coming through with the paint. Others is more porous. I've also read to "score" it to break integrity. Wouldn't that show through?
chrisn 02-23-2013 03:01 AM
I do not know what you are asking.
Is painted wall paper better that painted plywood?:huh:
Justins1171 02-23-2013 05:10 AM
I'd use a nice layer of BIN primer to seal the wallpaper from the paint, then paint over. You won't have any issues painting over the BIN with a latex
ToolSeeker 02-23-2013 08:24 AM
OK I'm a little confused also but here goes. You don't say what kind of room this is so I am going to assume it's a room that gets quite a bit of use.
As far as removing wall paper that has been up for 30 years the word nightmare comes to mind. Then to do anything with the plywood allthe paste (did you catch that Chris) has to be removed. Then the seams will have to be dealt with as in filled. And it's hard to paint plywood with out the grain showing thru.
As much as I don't like painted wallpaper it may be a better option. You don't say if the wallpaper is colored or has a pattern, if either I would prime with Cover Stain. It is oil based so be ready for the odor and the hassle of clean-up. But if you use a water based primer the water can loosen the paper. BIN would probably work but in this situation I would use the oil.
The 3rd option is remove all of it, update your insulation and wiring(if it needs it) and put up sheet rock.
chrisn 02-23-2013 04:54 PM
Certainly cover stain as opposed to Bin, if , for some reason it cannot be removed.
cdaniels 02-23-2013 08:50 PM
Is this in a house? Never seen plywood walls in anything but a shed or barn.
