Wallpaper Is Not Coming Off! - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 10:23 PM   #16
Rewards Points: 4,796
Originally Posted by ront02769 View Post
If you are going to sell the house to someone that you don't like, by all meansaint over the paper.
?? Painted over correctly, it works fine. Perhaps you only notice the jobs that were botched. The ones that look fine, you wouldn't know they were painted over wallpaper.
jeffnc is offline   Reply With Quote
Old 04-14-2014, 02:11 AM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
Read gymshu's post #11
then read it again
chrisn is online now   Reply With Quote
Old 04-14-2014, 08:06 AM   #18
Rewards Points: 440
The point is that at some point someone will want to remove and do new paper.....and that which has been painted is doubly hard to remove. Ron
ront02769 is offline   Reply With Quote
Old 04-14-2014, 08:28 AM   #19
If wallpaper has been painted over correctly, then no one would think to remove the old first. If it was the original homeowner, they would know it was too hard to remove the first time, so they would just wallpaper over the paint. If was a new owner, they would never know it was ever wallpapered, so they would also wallpaper over the paint.
The only reason you would paint over wallpaper in the first place is if it was difficult to impossible to remove, so obviously trying to remove after painting would be out of the question.
Yes, there are people that paint over wallpaper without even trying to remove it. I'm not talking about that case - that's not what I'd advise to do.
Old 04-14-2014, 09:03 AM   #20
Rewards Points: 5,974
And truthfully a lot of them have failures. Yes some get away with it. But your taking the chance of the water in the paint finding a few places where it's not stuck so good so a few months into it you start getting bubbles in your paint. Or along the seams. I have seen this happen even with oil primer used first.
Old 04-14-2014, 12:23 PM   #21
Rewards Points: 2,166
Josie, I'm in the same situation. Took me 4 months to finish kitchen, then a couple if months on a bathrm.
My best tool is a long handle scraper with Replaceable 4" blade. Water, water, water is key.
Everything I learned was on here. I'm working on final room, my bathroom, and bored out of my mind, so quit for awhile.
Perseverance! It's all worth it in the end. What's hard for me now is awkward places, behind toilet, plus areas up high where I have to work on a ladder.
Just keep plugging along and eventually you'll get done.
Startingover is offline   Reply With Quote
The Following 3 Users Say Thank You to Startingover For This Useful Post:
Gymschu (04-14-2014), ltd (04-14-2014), ToolSeeker (04-14-2014)
Old 04-14-2014, 03:52 PM   #22
Rewards Points: 18
Wow,
Thank you all very much for the help. Ill take all the suggestions into account. I'm definitely going to try and keep plugging away at this untill something works. At the same time I will exercise Patience, Patience, and, Patience...
Thanks all for the help!
Joshie is offline   Reply With Quote
The Following User Says Thank You to Joshie For This Useful Post:
Startingover (04-14-2014)
Old 04-14-2014, 06:07 PM   #23
So to expand on toolseeker's point, even if you've decided you don't want to take the wallpaper off, you should still soak it well and look for places that it's separating. In other words, still try to remove what you can, even if it's not much. This will help get rid of bubbles that might form later on.
The Following User Says Thank You to jeffnc For This Useful Post:
Old 05-02-2014, 04:38 AM   #24
I had my first experience a few months back! Taking down wallpaper should be a capital punishment! In fact I told my children I had a new consequence for them next time they got in any trouble! I found vinegar and water work great and also an old credit card or gift card is an amazing cheap tool good luck! I'm now having to try and paint over my over scoring before I learned about the ones that cost almost nothing.
emerkh is offline   Reply With Quote
Old 05-02-2014, 04:39 AM   #25
Old 05-02-2014, 07:21 AM   #26
I would really advise against vinegar. It's very acidic and will soak into the drywall and drywall paper and the moisture in the latex paint can re activate it and give adhesion problems down the road. Cannot understand what the advantage to using it would be.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (05-02-2014)
Old 05-02-2014, 01:56 PM   #27
Rewards Points: 18
Wallpaper is off! Skimmed and painted!! Thank you all for the help! I want to post a picture but I don't know how haha.
ToolSeeker (05-02-2014)
Old 05-02-2014, 06:48 PM   #28
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,196
That's great.
Last time I took down wallpaper, it was still attached to the drywall.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 05-03-2014, 03:48 AM   #29
chrisn's Avatar
Rewards Points: 396
Originally Posted by 123pugsy View Post
That's great.
If whomever installed it had applied a proper primer( ie, wall covering primer) that would not happen
Old 05-05-2014, 07:08 PM   #30
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by ToolSeeker View Post
As stated adding fabric softener to the water really helps.
All that does is makes the job site smell pretty. I have done more wallpaper removal jobs than I can count. It's the water doing the work. The warmer the better.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Gymschu (05-05-2014)
Help: Sewage smell coming from shower drain! erikerikerik Plumbing 23 01-11-2014 02:09 AM
wallpaper directly on drywall best removal SuzanneCD Drywall & Plaster 3 11-17-2012 04:20 PM
Wallpaper removal & brown paper backing _alphaBeta_ Drywall & Plaster 4 09-10-2012 08:26 PM
Peeled wallpaper down to bare paper facing on drywall, can I hang new wallpaper? PICS tunabreath Painting 5 08-05-2012 09:18 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
