Wallpaper Issues - Painting - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 11:45 AM   #1
Wallpaper issues
After a water leak from our master shower I decided to attempt to tackle the bathroom remodel myself. My question is this...
The previous owners of this house put wallpaper up directly to drywall with no primer coat. I've worked for days trying every possible trick or chemical that I could find on here or elsewhere. I've got all the wallpaper off but there are still many areas of the wall that still have some of the paper behind the wallpaper that i simply can't get off...without messing drywall up anyways(which I already have in some places). So I sanded the entire wall and when running my hand over it, it feels smooth and flush. I am going to do a knockdown texture on the wall. Is it ok if that paper is still on there if its sanded flush?? I've read about a damaged drywall sealer. My plan was so seal it, texture it, prime it and then paint it. Do you foresee any problems in the future with this?? Thanks for the help!
raiderred222 is offline   Reply With Quote
Old 06-05-2013, 04:45 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
As long as you prime it first with Gardz and you are happy with the smoothness, then no
Old 06-05-2013, 06:14 PM   #3
Rewards Points: 13,968
Any form of texture in a bathroom is a really bad idea.
Painting over wallpaper that was (mostly) removed ? cody21 Painting 10 11-27-2012 01:38 AM
Bubbly plaster + wallpaper + paint alson Painting 12 11-21-2012 05:39 PM
How to remove wallpaper? catlam Painting 3 09-24-2010 10:14 AM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 05:03 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
