Wallpaper Edges - OK To Caulk At Baseboard? - Painting - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 10:30 PM   #1
Wallpaper edges - OK to caulk at baseboard?
Have never and will never install wallpaper.
However: guest bath already had it installed. Looks fine, except that on a couple of walls it is curling up a bit where it meets the baseboard.
I'm thinking we need to carefully restick it with wallpaper repair adhesive - prob. Zinsser's SureGrip Seam & Repair Adhesive.
THEN...
The wallpaper edges are not as 'crisp' as I'd like them to be, so I wondered if it's OK to then caulk that line where the cut edge of the paper meets the baseboard.
Or is this a bad idea?
FWIW, the edges are not currently caulked where they meet the base.
Appreciate your help!
lucymiella is offline   Reply With Quote
Old 06-17-2012, 04:47 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Sure you can, why not?
Old 06-17-2012, 04:48 AM   #3
chrisn's Avatar
Rewards Points: 124
THEN...
Boy, do I hate this attitude
Old 06-17-2012, 09:11 AM   #4
Gymschu's Avatar
Rewards Points: 230
I have seen it done and understand why you have to do it. If not done NEATLY your bathroom will look tacky..........sort of like an apartment bathroom. If you use a regular paintable caulk, it will collect dirt, etc. Using a silicone caulk is tricky but it dries to a glossier finish and can easily be wiped off. Which one you use may depend on the type of baseboard in the bath.
Gymschu is online now   Reply With Quote
Old 06-17-2012, 10:03 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
Just no to 100% silicone.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-19-2012, 07:17 AM   #6
Hey Brushjockey and Gymschu, for my own information and hopefully that of the original poster, what do you think of Dynaflex 230 in this situation? We had double pane windows installed in our home several years ago and the contractor used a caulk that looked so much more robust when applied and yet not like silicone rubber. I don`t recall the name but at that time he told me this particular caulk wasn`t readily available retail.
So a while back when I went to Home Depot to buy a small tube of caulk and this Dynaflex 230 was there. I bought it because the tube was all I needed and I didn`t want to waste a whole cylinder by letting it set up in my garage.
Anyway, I got home and started using this stuff and it had exactly the same properties the window guys caulk had exhibited. The viscosity of this stuff is high enough that you don`t get the little waves in it when you pull or push the tube along and I think it looks like a lot better job when you are finished? Have either of ya`ll had any experience with Dynaflex 230 and what would be your opinion?
MorknMindy is offline   Reply With Quote
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 12:41 PM
Best Bathroom Caulk for 2010? SimpleJack Plumbing 9 04-01-2010 05:12 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
