Wall Texture Bubbling Up - Painting - DIY Chatroom Home Improvement Forum
Old 03-29-2014, 11:13 AM   #1
wall texture bubbling up
A previous owner had the walls textured and now I have small areas that are bubbling up and peeling off. I have scraped off what I could but now I have areas with a smooth surface. What do I have to do to fix this so it doesn't look stupid when I paint the walls? Are those cans of texture the answer or is there another way to deal with this?
swhite is offline   Reply With Quote
Old 03-29-2014, 11:20 AM   #2
Any pictures?
Danahy is offline   Reply With Quote
The Following User Says Thank You to Danahy For This Useful Post:
ltd (03-29-2014)
Old 03-29-2014, 01:35 PM   #3
Gymschu's Avatar
Rewards Points: 226
Yup. This.
Or, you can opt to mix up some watered down joint compound and experiment with various tools to see if you can come up with the exact texture look to match what's on the wall now.
The Homax cans come in various texture patterns. You can look on the front of the cans to see which texture looks most like what you have and buy enough cans to do your patching.
Gymschu is online now   Reply With Quote
Old 03-29-2014, 04:43 PM   #4
Rewards Points: 5,974
Again there are so many textures out there we could really use a couple pics. If it's orange peel or knockdown those cans Shu recommend will work. Since peeling is a problem I would probably prime before you texture and after the texture.
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Wall Texture Frustration ahsoisee Drywall & Plaster 5 12-19-2011 03:24 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
