Wall Paper Removal And Paint Prep. - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 08:00 PM   #1
Wall paper removal and paint prep.
Question: after removing wall paper where the walls were not sized I am wondering if I should use Kilz on the rough edges of the backer paper before I float the wall?
mac44 is offline   Reply With Quote
Old 02-22-2014, 08:04 PM   #2
Rewards Points: 13,732
http://www.amazon.com/Zinsser-Gardz-.../dp/B000BZZ49G
Old 02-22-2014, 08:17 PM   #3
Gymschu's Avatar
Rewards Points: 842
By "backer paper" what do you mean exactly? If it's the leftover paper backing of the wallpaper than you need to wet that and remove it. Once you have all the paper off and all the adhesive residue off the wall you can use Joes's suggestion of Gardz primer to make the walls more presentable for skim coating or whatever else needs to be done before you finish the wall with paint or paper.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
joecaption (02-22-2014), ltd (02-22-2014)
Old 02-22-2014, 09:27 PM   #4
There was a layer of brown paper underneath the wallpaper and the seams were painted in a 4" wide strip. There were also two other layers of wall paper behind the "backer paper". AARGH!
Old 02-23-2014, 07:36 PM   #5
Painting Contractor
rbriggs82's Avatar
Sounds like a nightmare wallpaper job but yeah you have to remove the brown layer.
rbriggs82 is offline   Reply With Quote
Old 02-24-2014, 05:46 AM   #6
Rewards Points: 5,974
Too do it right you should remove ALL layers. I know this is not exactly what you want to hear. To put latex (water) over any paper could loosen it and cause bubbles which could cause bigger problems.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Priming after wall paper removal keano016 Painting 1 09-14-2009 03:13 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 07:57 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
