Wall Paper Not Sticking - Painting - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 10:05 AM   #1
mc2
Wall paper not sticking
Put up pre-pasted wallpaper yesterday...wet it thoroughly , booked for 5mins and applied to clean wall non gloss, 3 hours later one sheet fell down completely others are peeling off...what can i do re-wet and apply paste? What are my options? thanks in advance
mc2 is offline   Reply With Quote
Old 03-02-2009, 10:38 AM   #2
Rewards Points: 506
Did the wallpaper instructions mention anything about applying sizing/wallcovering primer first?
SirWired
sirwired is offline   Reply With Quote
Old 03-02-2009, 11:38 AM   #3
mc2
don't remember will check later...if so is the wallpaper ruined or can i repaste and rehang after sizing?
Old 03-03-2009, 04:08 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Walls must have a WALL COVERING primer first , forget the word sizing, it is not relevant in this ( or most any) case.What brand of paper? It MIGHT be possible to apply paste to the paper that fell down but I would not bet on it. I would go with a higher quality paper myself,after all you will be living with it( hopefully) a long time, especially if you do not prime the walls first with a WALL COVERING primer.
Old 03-07-2009, 11:00 PM   #5
Rewards Points: 27
I have done this myself and found that when I used a thin layer of vinyl paste along with the pre pasted paper it worked very well.
Buy the already mixed vinyl paste and mix it with water and make it thin to the touch that you can just about feel the paste in the water. Like a slimy water. Thats the best way I know how to explain it.
Don't put the pre pasted paper through any roller tray or anything like that just cut the paper to size and paste it on the table with a paste brush as though you are pasting regular paper. Fold it over three quarters the way up and then fold the left over piece back to touch the first fold edge. See instructions for paper hanging in a book.
Determined is offline   Reply With Quote
Old 03-08-2009, 01:26 AM   #6
Thats too bad it came off!
But you can always fix up the mess up. Try reapplying wallpaper adhesive to the wall paper and paste it again.
Dana
Dana11 is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
