Wall Paneling Keeps Bleeding After Painting - Painting - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 06:39 PM   #1
Wall paneling keeps bleeding after painting
I am having a problem with the dark wall paneling I just painted. After painting with an oil base primer and 2 coats of latex paint, there are bleed marks appearing through the paint. Should I used another coat of oil primer over the latex paint to stop the bleeding or not. What can I do?
Ronnie Herndon is offline   Reply With Quote
Old 10-03-2010, 10:11 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
You may have not put on a thick enouh coat of oil. If you think it was a thick enough coat and it is still bleeding, then you need Schellac based BIN.
Old 10-04-2010, 05:33 AM   #3
Painted wood paneling
Can you apply the schellac base bin primer over a latex paint just painted on the paneling.
Old 10-04-2010, 06:44 AM   #4
Yes you can.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
Painting 2-tone on a single wall question lmholmes11 Painting 3 07-18-2008 09:43 PM
wall paneling.. Klint Painting 3 08-04-2007 09:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
