Wall Paint Cracked And Poped Up - Painting - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 06:27 PM   #1
Rewards Points: 12
Wall Paint cracked and poped up
Hi, my house is a brand new constructed house, and I have a question.
This is the first time I own a house so I am not familiar with many things. I apologize if I asked a silly question.
Do you know what would cause paint to crack and pop up like the attached picture?
Thanks!!!
dc638 is offline   Reply With Quote
Old 03-11-2011, 06:51 PM   #2
Rewards Points: 530
Is that a small spot, or something more than a spot? Anymore places like that?
Old 03-11-2011, 06:59 PM   #3
Rewards Points: 526
That's a drywall nail (or screw) pop. They are a common problem in new homes.
Windows is offline   Reply With Quote
Old 03-11-2011, 07:20 PM   #4
Gymschu's Avatar
Rewards Points: 942
Def. a nail or screw pop. What I usually do is put a screw above and below that popped nail to pull the drywall back into the framing then remove the popped nail. Apply some spackle or joint compound, let dry, sand, prime, and repaint.
Old 03-11-2011, 08:15 PM   #5
Be ready, sometimes putting new screws in, recommended, will cause some others to pop.
Old 03-11-2011, 10:23 PM   #6
Rewards Points: 12
It is a small spot in couple different area in the house.
I think you guys are correct. Since it is a new home, it is still under warranty. I send an email to the builder just now and waiting for their reply. They promised me that they will come over to fix some cracked drywall so maybe they will fix that as well.
I love this forum. I think it will help me to get a lot of home improvement answers. Thanks a lot guys...
Old 03-12-2011, 06:16 AM   #7
Rewards Points: 530
Thats what I was thinking. That or a cake pan behind the dw.
Old 03-12-2011, 07:45 AM   #8
If you look at the top picture, you can see the outline of the screw head, which a lot of time is the first thing you'll see on the ceiling, before there is even any rise. I find them a lot and simply take a phillips and give the a couple of turns and simply spackle what amounts to a screw hole. They'll be full pops soon enough.
Old 03-13-2011, 09:10 AM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
Very common and easy to fix. Most times they will show up the day after the first coats of mud are applied but sometimes they don't show up till the house settles after a while.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
