Old 03-09-2011, 01:04 AM   #1
Question
wall frames
Hello everybody,
Are there any rules on the sizes of the wall frames? The size of my master bedroom is 20x15ft. The height of the highest wall is 12 ˝ ft., of the opposite wall – is 8ft. I would like to put a trim-molding around the whole room on the height of 8 ft. and then to make 3 “windows” to the upper rectangle of highest wall and one big “window” to lowest wall. I have really hard time to figure out the best size of these “wall frames”. I would really appreciate your advice on that.
mryvkina is offline   Reply With Quote
Old 03-10-2011, 09:22 AM   #2
wall frames
I would post this message in the interior decorating forum next door. Personally, I think a one foot border would be appropriate. Size the three rectangles to have one foot above the lower large one, with a foot from the ceiling and a foot between surrounding.
Old 03-14-2011, 12:50 AM   #3
wall frames
Thank you so much,
Marina
Old 03-14-2011, 06:08 AM   #4
wall frames
Glad to help, good luck.
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Replacing load bearing wall KarlJay Building & Construction 3 01-05-2011 05:03 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
