Wainscoting And Trim.....same Sheen? - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 04:13 PM   #1
Rewards Points: 77
Wainscoting and trim.....same sheen?
I have been doing the trim in the rooms I've redone in my house with SW Proclassic semi-gloss. I will be moving into the kitchen and living room soon and we have some wainscoting with trim on top and baseboards. Question is: do I use the same sheen on both? I like the look of the semi-gloss in the other rooms, but like the wainscoting with more of a matte or flat finish. Can I do different sheens in them or should I bump the trim sheen down to a satin so there isn't a big contrast?
asbury park is offline   Reply With Quote
Old 02-23-2012, 04:16 PM   #2
Rewards Points: 77
Here is a pic of one of the walls. That ugly paint is finally about to disappear.
Old 02-23-2012, 04:18 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 608
Typically it would be the same sheen, but, hey, it's your'e home, do whatever floats your'e boat
The Following User Says Thank You to chrisn For This Useful Post:
ltd (02-23-2012)
Old 02-23-2012, 04:32 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
It looks like what your calling wainscoting is the wall below a chair rail. if it were something like tongue and groove wood- I would definitely go with the same sheen ,if not also color, as trim. But because it is wall, it could be another ( or the same) wall paint sheen trimmed with the trim paint.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-23-2012, 04:56 PM   #5
Brush, you can't see that the lower wall area IS t&g? The vertical lines are pretty visible. OP, while you can paint the wains any color/sheen you like, standard treatment is to match the trim.
Old 02-23-2012, 04:59 PM   #6
Rewards Points: 77
So that doesn't classify as wainscoting? Beadboard trimmed out with chair rail and baseboard? Either way, i think i may like the same sheen idea which would push me towards a satin. What's the best approach to paint beadboard? Brush? Roller (what nap)?
Old 02-23-2012, 05:08 PM   #7
I didn't see the lines- but I did cover how to approach it if it was T&G..
I like to roll a few boards and then brush it into the cracks and lay off smooth with the brush. Goes pretty quick once you get the feel of your material.
Old 02-23-2012, 05:13 PM   #8
Rewards Points: 14,300
I paint my trim semi gloss and the beaded paneling satin. Reason being it make it stand out a little more instead of having it just blend in.
If you use a 1/2" nap roller it will fill in most of the low spots where the beads are.
I use a sash brush to paint the panels at least 4" from the other trim and try to brush away from the trim not towards it. Try to keep the roller away from the trim. The reason is the paint will keep running down the beads and pile up at the bottom making a mess.
Old 02-23-2012, 05:24 PM   #9
Rewards Points: 77
Will Proclassic be tough to work with on the beadboard? I do fine with it on trim, but i can see it being tricky on the beadboard if i don't move fast enough.
Old 02-23-2012, 09:53 PM   #10
Asbury, as Brushjockey said, do only a few sections at a time, a manageable few. Use the natural grooves in the t&g to segment the portions and control your wet edge. Start with smaller segments first to get a feel for how it's going keeping a wet edge. Use a mini roller and then lay off with a brush.
Old 02-24-2012, 02:50 PM   #11
Rewards Points: 77
Ahhhhh, i see. Thanks
Old 02-25-2012, 08:07 AM   #12
Rewards Points: 101
I just brush the wainscoting. Use a 2.5 inch brush and take two sections/ slats at a time. No need to get a roller involved. You would be back brushing anyway to get rid of the orange peel look so I don't see the point. Just take your time and brush it. As for what sheen you go with, it's is up to you, if you want a different sheen on the trim that is fine as long as you are happy with it.
JMDPainting is offline   Reply With Quote
Attaching wainscoting directly to studs or drywall? mjzraz Carpentry 15 11-03-2012 08:43 AM
How to end wainscoting? Smitty31 Windows and Doors 3 02-21-2012 09:54 PM
Beadboard Wainscoting Down Stairs jimmycrackcode Carpentry 5 02-08-2012 02:21 PM
Drowning in wood wainscoting nlawson Introductions 10 06-26-2011 09:05 PM
cutting trim to fit angles Davidb6 Carpentry 5 07-09-2009 01:29 PM
