Wainscoting Repair - Painting - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 08:34 PM   #1
Wainscoting repair
I've posted before about the disaster paint job my bathroom had when we bought this house. Believe it or not, it was new construction. Anyway, I'm tackling the repair job and was hoping to get some help on where to start, and best practices. I've painted a lot, but am new to the repair aspect. There are cracks in the painted wainscoting, and they did a terrible job where the wood meets the tub (see pic). Would a wood putty be the best thing for the cracks? would I use calk where the wood meets the tub? Any advice for sanding down other imperfections in the wood? Any advice would be appreciated!
Leanne1 is offline   Reply With Quote
Old 10-02-2011, 08:36 PM   #2
Rewards Points: 150
Thats new construction?!?!?!? Id have the builder by his ballz in there fixing it himself on a Sunday...
OhioHomeDoctor is offline   Reply With Quote
Old 10-02-2011, 08:47 PM   #3
It was a foreclosure on the builder so we bought it from a bank.
Old 10-02-2011, 10:47 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Ya- petty ugly.
Get a good caulk gun, because you're going to learn how to use it. Small fills like that are done with caulk, but the trick is to finger it in place and wipe away the excess.
Not nearly as easy as it would seem.
Do a google on how to caulk- watch/ read a few so you aren't taught by some tv fool who doesn't know..
And NEVER use 100% silicone- always look for PAINTABLE on it!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-03-2011, 03:32 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Originally Posted by Brushjockey View Post
Ya- petty ugly.
NEVER,EVER
Old 10-03-2011, 05:33 AM   #6
Not surprised he was foreclosed on. I would take a piece of 120 grit sandpaper and give the area a good sanding first. Your not sanding for bonding, but for smoothing out a rough surface. Use 100 paper any real bad areas. It also looks like some nails need to be set. Take a nail punch and lightly tap the nail heads just below the surface, then overfill the hole with lightweight vinyl spackle, when it dries sand it smooth. Here is a thread with some info about and on caulking Trim caulking before paint?
Joe
Old 10-04-2011, 04:44 PM   #7
Thanks to everyone for the info!!
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
