Wagner 1420 Sprayer Not Working - Painting - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 02:37 PM   #1
wagner 1420 sprayer not working
I have a basement to paint, and have a sprayer. It's a wagner 1420. However, it's not working. I can't get it to spray at all. It seems like it never reaches pressure, and not much ever comes out.
I have a couple questions:
1. Is this the right forum for this question? If not, please tell me where.
2. Are there some things I can try that'll help me understand what's going on with it. Is there a valve I need to close? I'd really like to try to figure out what's up with it, I don't really have the time to take it to the repair place.
mattkslc is offline   Reply With Quote
Old 03-06-2011, 02:44 PM   #2
Coatings Nerd
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-06-2011, 04:05 PM   #3
firehawkmph's Avatar
Rewards Points: 1,858
Matt,
I have a titon 440 airless that did the same thing. Turns out there is a check ball inside that needs to seal in order to build pressure. My sprayer just sat there churning away but wouldn't build pressure or stop churning. I took it in to SW and their repair center took it apart and cleaned everything out and repacked it for $150. Mine didn't have a lot of time on it and would sit for long periods of time without being used. I think that's worse for them than not using them.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 03-07-2011, 10:53 AM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Make sure your inlet filter and any other filters are clean. There should be a ball, it may be stuck. Sounds like its not priming fully. Make sure the inlet hose is clear inside of it. Some sprayer have a button to unstick the ball valve, check for that. Try running some thinner through it. Followed by water. It may be caked up with paint inside. Make sure to add the proper throat oil to it also, sometimes the oil will free it up too.
housepaintingny is offline   Reply With Quote
Old 03-07-2011, 12:33 PM   #5
Finisher
It's a wagner, so i'm not familiar with it, but on most professional pumps there is a metal part at the top of the syphon (the pump housing) that attaches to the body of the sprayer. Try hitting that with a hammer a couple of times while you've got the machine priming and see if it un-sticks the ball inside it. That is almost certainly the problem.
Rcon is offline   Reply With Quote
Old 03-07-2011, 12:56 PM   #6
Gymschu's Avatar
Rewards Points: 648
Never could get much production out of a Wagner. Usually we would just buy their cheap version and use it one time.......that's about all it was good for. Pain in the butt to clean up........
Gymschu is online now   Reply With Quote
Old 03-07-2011, 06:58 PM   #7
Wagner= one and done.
kboyz is offline   Reply With Quote
Tags
paint , painting , sprayer , wagner
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 06:23 AM
wagner hvlp control sprayer momof2labs Painting 9 11-03-2010 02:31 PM
kitchen sprayer troubleshooting jhustwit Plumbing 6 06-14-2010 01:46 AM
Need Advice on a Paint Sprayer HandyFrank Painting 15 01-09-2010 10:59 PM
