Vinyl Trim To Paint Or Not To Paint - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 09:24 PM   #1
vinyl trim to paint or not to paint
Our 135-year-old house has beige vinyl siding, and the trim is yellow. I'd like to change the look by changing the color of the trim. Of course, when they put the siding up, they put up yellow trim pieces. What are some ways to change the trim pieces to white? Do we have to take down every piece of trim and replace it with the different color? Can we paint it with a paint compatible with vinyl siding? If so, what kind of paint would that be?
Nosey is offline   Reply With Quote
Old 07-25-2012, 09:39 PM   #2
Paint Pro
i think the most crucual thing is the color you chose. warping/buckling can occur if you dont chose a vinyl safe color. check out SW vinyl safe color pallettes/products
Expert Paint is offline   Reply With Quote
Old 07-26-2012, 04:17 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
they said white
Old 07-26-2012, 06:51 AM   #4
Too Short? Cut it Again!
Adhesion is your challenge so be sure the trim you are painting is spotlessly clean. Scruff up the vinyl with either fine grit paper or a vinyl chemical prep. Then I would apply a quality paint store, not box store, high bond waterbased primer claiming it will stick to vinyl or a plastic primer (Rustoleum makes a nice one in liquid form). Finally apply two coats of finish.
Not sure why color would effect adhesion but I guess it makes some sense. Vinyl expands/contracts and shape changes to some extent when warm more dramatically than some other building materials. I suppose heavily pigmented paints would leave more material on the surface that has to flex with it. Also and obviously darker colors would draw heat into the material while lighter ones would reflect it.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Prepping old trim for fresh paint (chipping paint) housegsx Painting 6 11-18-2011 07:26 AM
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 06:45 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
