Vinyl Siding - Can I Paint It? - Painting - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 07:02 PM   #1
Vinyl Siding - Can I paint it?
Can vinyl siding be painted?
waitegarry is offline   Reply With Quote
Old 10-28-2008, 08:53 PM   #2
Yes it can be painted! But will the paint adhere?
Old 10-29-2008, 12:49 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
I wouldn't paint it.
Old 10-29-2008, 04:10 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 304
Taken from another site
If you decide to paint, you will lose the maintenance free quality of vinyl. You might need to paint every 10 years.
The secret to painting your vinyl siding lies in the procedure.
1. Start by cleaning all the dirt and mildew accumulated through the years. The siding can be cleaned by hand scrubbing or by power washing it. There are many cleaners available at your local hardware store. After cleaning it, it is important to rinse it thoroughly. If you skip this step, the paint will not adhere to the surface. 2. You are now ready to paint!
a. Vinyl siding has a very high coefficient of elasticity. This means that it expands or contracts depending on the temperature. This quality makes it challenging to paint.
b. In you want your new painted surface to last a long time, you will need to chose a high grade acrylic latex paint. This paint has extraordinary bonding capabilities. It will expand and contract with the vinyl without cracking.
c. A new color scheme can also be used. However, the new color must be lighter than the original color. Each vinyl siding is manufactured to resist specific levels of heat. If you chose a darker color, your “new” siding will absorb more heat. This could have some ugly consequences – your siding might warp or buckle.
d. Try not to paint under the direct sunlight if possible. Overcast weather produces better results.
chrisn is online now   Reply With Quote
Old 10-29-2008, 06:39 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Sherwin-Williams and others make paint specifically for vinyl siding. Follow the manufacturers instructions.
Old 10-29-2008, 01:53 PM   #6
Rewards Points: 506
Actually, SWP doesn't have special Vinyl Siding paint, (at least, not that I know about), but they do have a pre-approved color palette with "vinyl safe" colors. I think it has to do with the chemical formulation of different SWP colorants, maybe some of which work on Vinyl, some of which don't.
SirWired
sirwired is offline   Reply With Quote
Old 10-30-2008, 06:45 AM   #7
The last I looked, they had a latex that was rated for superior adhesion to vinyl siding. It may be marketed under a Duron label which is a subsidiary of S-W. Pretty sure that Glidden had one too.
Old 10-30-2008, 11:01 AM   #8
I guess I will be a little more elaborate. You will be taking a state of the art technology siding and make it prone to chipping, cracking, fading and peeling if you paint it. Is the color really that bad?
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 06:45 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
