Venitian Plaster Faux Painting Using Drywall Compound? - Painting - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 03:52 PM   #1
crankcase's Avatar
Venitian plaster faux painting using drywall compound?
I wasn't sure if this should be posted under painting or drywall but we'll give it a try.
A few years ago I did a painting technique where I used drywall compound with a 6' knife over a whole bathroom in a venitian plaster type of effect that I want to try again. There were slight ridge marks left from the knife edges after I went over the whole room, then I painted with a base coat, then I did a color wash in a tint maybe 3 shades off from our base coat. Followed up with a clear glaze topcoat.
It really came out good, I wish I had some pictures. Now here's my question:
I know that I used drywall compound, but I was told to add something to it to make the drywall mud to be a little harder and not be so soft when it set up. Vinegar comes to mind, but I can't remember for sure anymore. Is this correct?
I usually use USG plus3 all purpose drywall compound (blue top pail), but maybe I would be better off with something like the green top stuff which is called out for taping if I remember correctly. Otherwise I could try the setting type 30 or 45 minute catalist type in small batches.
Would anyone have any suggestions?
crankcase is offline   Reply With Quote
Old 02-16-2011, 07:52 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
The setting compund will dry harder but you really want the 90 or even the 120 but the 120 is harder to find.
Old 02-16-2011, 03:10 PM   #3
crankcase's Avatar
Thanks Matthew, I know I'vee seen the 90 min for sure , never used it though. I will try that.
Old 02-18-2011, 07:51 PM   #4
Coatings Nerd
Are you using the brown bag or white bag? Brown bag should dry harder.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Drywall installed over plaster brait97 Building & Construction 2 09-20-2010 04:28 PM
How do you intersect drywall (or in my case plaster) into tile on the same plane? Proby Kitchen & Bath Remodeling 5 08-02-2010 05:51 PM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
