Varnish On Painted Propane Tank - Painting - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 05:29 PM   #1
varnish on painted propane tank
What kind of varnish or protective coating is used on a propane tank that is exposed to 14 hours of sunlight each day? I want to paint a design using only pastel colors and will need the colors to last.
ChatKat is offline   Reply With Quote
Old 07-05-2012, 08:12 PM   #2
Too Short? Cut it Again!
I would use One Shot alkyd sign painter's enamel for your design. It comes in nice pastel colors. It is thicker than other paints so will not "crawl" when you apply it. Cover with a good automotive clear coat that has good UV protection. A couple rattle cans from the auto supply store should do the trick.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 06:23 PM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 10:21 AM
Propane Range hookup to 20lbs tank? PaoloM HVAC 0 06-09-2010 11:47 AM
septic tank problems. littles Plumbing 1 02-24-2010 10:30 PM
