Valspar Venetian Plaster - Painting - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 09:16 PM   #1
valspar venetian plaster
Shalom to all who read this
I am painting my house and have decided to do a faux finish using the valspar venetian plaster and just want to know if on my second and/or third coats if I can mix two different valspar ventian colors
yahebed is offline   Reply With Quote
Old 01-24-2011, 09:58 AM   #2
I think "mixing it up" a bit will result in an awesome diverse finished product. Have you considered burnishing the last coat? Also, you may not need to apply a final clear coat if the room is anything other than a kitchen or bathroom.
Post pictures so we can see.
HDPaintPro is offline   Reply With Quote
Old 01-24-2011, 10:58 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I wouldn't think there would be a problem but it would be wise to ask the manufacturer or a manuf. rep to be sure.
I have seen other similar systems and they specifically use at least 2 colors. It adds a lot of interest to the wall. I would also suggest a burnished finish. That is what Venetian plaster is all about. It's a lot of hard work but I think it looks great.
be sure to make test panels of any ideas you have. It's tough to repair or work over something already on the wall. Much easier to duplicate a test panel that turns out how you like.
Just make an effort to remember or even video record your attempts on the test panels so you know how you got to the result you have. If you end up with 4-6-10 test panels, you might tend to forget how you got the result on that panel.
Old 01-24-2011, 11:57 AM   #4
Great reply nap!
nap brings up a great point:keep close records on what you did, how you did it and with what products you used. Also, save a little bit of each color and seal it up in a tight container (plastic snap lid container). Write the name on the side and the date. Also, try and record any product numbers as well.
If for whatever reason you may need to repair a section of the walls - you have the exact materials at your disposal.
Faking Venetian Plaster / Knockdown (Sort of) PTP WX Drywall & Plaster 6 01-26-2011 04:59 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Venetian Plaster Fireplace Plaster Ayn Painting 0 01-19-2010 10:42 AM
Venetian Plaster Plaster Ayn Painting 10 12-01-2009 06:40 PM
venetian plaster farrington135 Painting 1 01-02-2006 05:44 PM
