Old 02-03-2013, 10:43 AM   #1
Valspar Primer and Behr paint is ok? For Fiber Cement Siding.
Is it ok? to use Valspar Exterior Latex Primer and after that to paint with Behr? Is for a Fiber-Cement Siding
Thank You....
JBTECH is offline   Reply With Quote
Old 02-03-2013, 11:05 AM   #2
Most Hardee board comes preprimed so it may not be needed.
Zinzeer 123 and Sherwin Willaims Super paint or Duration would be my first choises.
Not going to find many Behr fan here.
Old 02-03-2013, 11:06 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
I guess your other thread wasn't good enough?
You want to go cheap rather than good- no one can stop you.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (02-03-2013)
Old 02-03-2013, 11:12 AM   #4
Must like sanding scraping and painting. Cheap paint always cost more in the long run.
Old 02-03-2013, 11:46 AM   #5
The Fiber Siding that I am installing is not pre-primed, I need advice is valspar primer good?
Thanks for your help....
Old 02-03-2013, 11:48 AM   #6
visit a sherwin williams or benjamin moore store.
Old 02-03-2013, 11:52 AM   #7
cdaniels's Avatar
No....it's not that cheap either.You can get Zinsser 1-2-3 for about the same price and it is good.As far as the Behr I can't say I have never used it but I have not heard good things about it.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-03-2013, 12:03 PM   #8
747
registered
747's Avatar
Listen bulleye 123 isn't big money and its an excellent primer sealer. Go and grab 5 gallon container at your home improvment center. Then go with sw super paint or duration. Last time i bought 123 it was on sale at menards a gallon was 11 dollars It was a couple years ago. Its a good rich primer.
747 is offline   Reply With Quote
Old 02-03-2013, 12:14 PM   #9
ok I will try bulleye 123 primer, is safe for fiber cement siding?
Thanks again....
Old 02-03-2013, 12:21 PM   #10
cdaniels's Avatar
Yes....just make sure you get the one for that is interior/exterior....there is one for interior only.
Old 02-03-2013, 12:40 PM   #11
ok thanks a lot!!!! and for paint which brand do you recommend?
Old 02-03-2013, 01:44 PM   #12
Gymschu's Avatar
I think we are being "trolled."
Old 02-03-2013, 03:22 PM   #13
747
registered
747's Avatar
Sherwin Williams super paint or duration. Seeing how your on a budget which ever is cheapest.
Also call around lowes and menards and Homedepot. Ask them how much are they sellinig bulleye 123 interior exterior primer sealer for. 5 gallon container. Go with cheapest place. It comes in 1 gallon and 5 gallon. Make sure they shake it up. 5 gallon will getting you moving. When you run out repurchase according to how much house is left.
Old 02-03-2013, 05:45 PM   #14
paper hanger and painter
chrisn's Avatar
Behr,premium,ultra, plus,super,one coat,stain blocker,fantastic,un-believably good, spectacular,fabulous,primer,hole filler,all around consumer reports #1 paint.
thats what I would use
Old 02-04-2013, 05:50 PM   #15
Thank You....
yep just to let you know it is OK not the best but ok. Just remember this a high quality paint and a low quality paint may go on in the same mil thickness but dry and leave you with two diffrent mil's always go with a paint that uses high quality resins and binders. they will always save you money in the long run. James hardi siding not primed? did not know it came un primed? that is new to me. last time they made un primed was around 1998.
Nailbags is offline   Reply With Quote
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 15 03-24-2011 11:20 AM
Behr Paint and Primer in one. Matthewt1970 Painting 9 09-30-2010 05:48 PM
Using new Behr Paint & Primer in One...will report back with results BigMatty Painting 2 06-23-2009 10:43 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
