-   -   Valspar Primer and Behr paint is ok? For Fiber Cement Siding. (http://www.diychatroom.com/f4/valspar-primer-behr-paint-ok-fiber-cement-siding-170893/)
JBTECH 02-03-2013 09:43 AM
Is it ok? to use Valspar Exterior Latex Primer and after that to paint with Behr? Is for a Fiber-Cement Siding
Thank You....
joecaption 02-03-2013 10:05 AM
Most Hardee board comes preprimed so it may not be needed.
Zinzeer 123 and Sherwin Willaims Super paint or Duration would be my first choises.
Not going to find many Behr fan here.
Brushjockey 02-03-2013 10:06 AM
I guess your other thread wasn't good enough?
You want to go cheap rather than good- no one can stop you.
joecaption 02-03-2013 10:12 AM
Must like sanding scraping and painting. Cheap paint always cost more in the long run.
JBTECH 02-03-2013 10:46 AM
Siding is not pre-primed
The Fiber Siding that I am installing is not pre-primed, I need advice is valspar primer good?
Thanks for your help....
DannyT 02-03-2013 10:48 AM
visit a sherwin williams or benjamin moore store.
cdaniels 02-03-2013 10:52 AM
No....it's not that cheap either.You can get Zinsser 1-2-3 for about the same price and it is good.As far as the Behr I can't say I have never used it but I have not heard good things about it.
747 02-03-2013 11:03 AM
Listen bulleye 123 isn't big money and its an excellent primer sealer. Go and grab 5 gallon container at your home improvment center. Then go with sw super paint or duration. Last time i bought 123 it was on sale at menards a gallon was 11 dollars:thumbsup: It was a couple years ago. Its a good rich primer.
JBTECH 02-03-2013 11:14 AM
Thankss!!!
ok I will try bulleye 123 primer, is safe for fiber cement siding?
Thanks again....
cdaniels 02-03-2013 11:21 AM
Yes....just make sure you get the one for that is interior/exterior....there is one for interior only.
JBTECH 02-03-2013 11:40 AM
Ok
ok thanks a lot!!!! and for paint which brand do you recommend?
Gymschu 02-03-2013 12:44 PM
I think we are being "trolled."
747 02-03-2013 02:22 PM
Sherwin Williams super paint or duration. Seeing how your on a budget which ever is cheapest.
Also call around lowes and menards and Homedepot. Ask them how much are they sellinig bulleye 123 interior exterior primer sealer for. 5 gallon container. Go with cheapest place. It comes in 1 gallon and 5 gallon. Make sure they shake it up. 5 gallon will getting you moving. When you run out repurchase according to how much house is left.
chrisn 02-03-2013 04:45 PM
Behr,premium,ultra, plus,super,one coat,stain blocker,fantastic,un-believably good, spectacular,fabulous,primer,hole filler,all around consumer reports #1 paint.
thats what I would use:whistling2:
Nailbags 02-04-2013 04:50 PM
Thank You....
yep just to let you know it is OK not the best but ok. Just remember this a high quality paint and a low quality paint may go on in the same mil thickness but dry and leave you with two diffrent mil's always go with a paint that uses high quality resins and binders. they will always save you money in the long run. James hardi siding not primed? did not know it came un primed? that is new to me. last time they made un primed was around 1998.
