Valspar Paint And Rollers - Painting - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 04:03 PM   #1
Rewards Points: 640
valspar paint and rollers
I am painting a basement room with valspar paint, which of course is thicker then most normal paint... what would you recommend for a roller cover to use? This is just a normal flat surface wall, and I am using a light colored (Tan) semi-gloss paint thanks!
BlueBSH is offline   Reply With Quote
Old 01-25-2010, 06:27 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Wooster pro classic 1/2 merino wool $9.50 at Lowes.
Kevin
Kevin M. is offline   Reply With Quote
Old 01-26-2010, 02:40 AM   #3
Exotic NooB
I am a brush guy... The paint is thick and yearns to be manhandled.
Besides, you get a great workout and you build your forearms like no tomorrow. Chicks dig guys with arms. Even if you already have a full time chick. She will appreciate you even more. You wont need to answer the e-mails about being small, or call those 800 numbers for the special pills.
My great grandfather was a painter and he lived forever and had over 15 children. He just used a paintbrush. He would say, "Rollers are for sissys." You need to go out and get yourself a fat nylon #5" and you let the wall know who the man of the house is.
Don't cheat youself.
inlikeflint is offline   Reply With Quote
Old 01-26-2010, 05:07 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Are you serious?
Old 01-26-2010, 12:18 PM   #5
I would recommend contacting Valspar directly for their recommendation. I believe it depends on the actual type of paint that you are using vs. the brand (i.e. oil based, etc.) Here is their number: 800-845-9061
DecoratingDiva2 is offline   Reply With Quote
Old 01-26-2010, 01:07 PM   #6
Rewards Points: 640
yeah, I'm not exactly going to brush paint 3000 sq ft of wall space...... and I hate brush marks, rollers give it a much more smooth texture...
Old 01-29-2010, 11:05 AM   #7
Sherwin Williams contractor grade are also very nice 1/2" nap
samiller1980 is offline   Reply With Quote
Old 02-01-2010, 01:10 AM   #8
Faron79's Avatar
Rewards Points: 260
Wow...
An old painter who used a brush for everything?!?!?
Was his car a steam-powered unit?!??!
IMO...the best roller-covers are the Purdy White-Doves; OR the Wooster Pro-Dooz's. Corona has awesome covers also...if your store has them.
You'll waste money on "Contractor-grade" covers. Don't make that mistake!
I'm always amazed at the "I've got good paint, and just need a cheap cover..."-logic.
...lordy...lordy...
Faron
Faron79 is offline   Reply With Quote
Old 02-01-2010, 03:57 AM   #9
chrisn's Avatar
Rewards Points: 228
...lordy...lordy...
Faron
He did not have GOOD paint to begin with.
Old 02-01-2010, 01:31 PM   #10
wasn't going to say anything about the fact that valspar was being used. when using valspar I don't think it matters what you use to put it on the walls. Not a paint I would pay for. Second I have painted literally hundreds of houses with Sherwin Williams contractor grade roller covers and have never had a problem except for the occasional flat spot on cover but have had them with purdy as well. As for cheap. Cost about the same as a purdy.
Old 02-01-2010, 03:01 PM   #11
I've got some Purdy and SW Contractor covers and I would buy either one again with no hesitation. I personally like the Purdy a bit more but that could simply be the difference in applying paint and primer (Purdy vs. SW respectively.)
cellophane is offline   Reply With Quote
Messy Paint Rollers! paintbros Painting 14 07-25-2009 09:54 PM
Paint Rollers & Sleeves saggdevil Painting 3 05-23-2009 09:51 AM
I think I was stiffed by a Paint Contractor. Any advice? Shaun_in_NC Painting 4 09-28-2008 09:13 AM
