Using The Same Brand Of Paint. - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 11:32 AM   #1
using the same brand of paint.
Is it necessary to use the same brand of primer and paint? I want to paint my door molding with a latex and they have oil on them now.
Lynne-e is offline   Reply With Quote
Old 04-29-2013, 01:10 PM   #2
Gymschu's Avatar
Rewards Points: 462
Not necessary, but, for the sake of continuity I usually buy the same brand of primer and paint. The chemistry of paint is such nowadays that each company has a "system" which makes the paint finish a better product in the end if you stay with the same co. But, like I said, it's not necessary. I have used Valspar primer and SW for walls and had no issues.
If you are going from a glossy oil to a latex........scuff sand and use a bonding primer first before applying the finish coats. Those oils can be so glossy that you get "fish eyes" in your finish and bonding issues if you don't use a bonding primer such as Zinsser's 1-2-3.
Gymschu is online now   Reply With Quote
Old 04-29-2013, 08:31 PM   #3
Too Short? Cut it Again!
If you do not mind working with a solvent based primer, and assuming you can buy it where you live, I still like going with an alkyd primer/underlay over oil finish and then putting on two coats of a nice acrylic finish of quality.
A bonding latex primer will work though. As mentioned, you must scruff up the surface with fine grit paper so the primer will stick. You will want to wash the surfaces if the oil product has chalked.
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
