#1 |
Using Polyurethane
I finished staining 3 new interior oak doors. I'm ready to add the polyurethane. My question is, do I have to sand my newly stained door before I add the first coat of polyurethane?
#2 |
Stay-at-home GC
Using Polyurethane
Depends on how smooth you want the final product.
Doesn't hurt as long as you are using the finest grain paper you can find and stay with the grain. Do your sanding somewhere other than where you will be doing your poly and be sure and tack cloth after each sanding.
Can correctly identify Shinola 3 out of 5 times* *Under ideal conditions Some days, my Life needs a Rewind/Erase Button. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to CplDevilDog For This Useful Post: | DangerMouse (03-24-2011) |
#3 |
Using Polyurethane
Thank you - your response is very helpful...
One more question - is it okay to use spar urethane on an interior door? A friend recommended using this instead of polyurethane. Although, everything i've read leads me to believe this is exterior only. Any preference? |
#4 | |
Using PolyurethaneQuote:
If the interior doors frequently recieves sunlight, then yes. Apply 1st polyurethane coat. Use 320 lightly sand and so on Last edited by StevenH; 03-25-2011 at 04:23 PM. |
#5 |
Painting Company, NY
Using Polyurethane
Sanding before poly coat is not always necessary. If you sanded well before staining and used a tack cloth to remove all dust then your finish will be pretty smooth. You can lightly sand or use 000 steel wool if you feel its necessary. Spar is an exterior polyurethane. it contains UV protection, which your interior polys don't have. You can apply your poly directly over your stain. 2-3 coats of poly.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 | |
Coatings Nerd
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service |
#7 |
Using Polyurethane
just finished polyurethane on a bar top wished i would have used grain sealer. It's oak but coated it 6 or 7 time 320 grit sand paper between coat came out great take your time
#8 |
Jack of all trades
Using Polyurethane
I have done many projects that I have finished with Poly. I sand or use steel wool between ech coat. If you want a real glossy finish I would recommend steel wool and tach cloth between coats. If you don't have a tach cloth put some mineral spirits on a white (used a red rag once...lol) rag and wipe with that. It works great.
#9 |
Using Polyurethane
You'd have to have some serious splinters or pebbles on a newly stained door to feel them after three coats of poly. I, personally, would never touch freshly stained wood with a piece of sandpaper or steel wool. The risk of cutting to raw wood or marring the uniformity of the stain is too great for the minimal return it would accomplish. Put the first coat on, give a good sand, tack it down, recoat, light sand, tack, recoat, done. Important: Either strain your poly before each use or pour enough off to do three doors, when done set that aside, pour off more from the gallon for the second coat, ie, always be sure your clear is clean.
Edit: If you didn't do the proper sanding before staining, after staining and before the first clear, is not the time to do it.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by jsheridan; 03-27-2011 at 05:24 PM. |
#10 | |
I've seen people sand off the stain color or to bare wood, which is not pleasant do.
| The Following User Says Thank You to StevenH For This Useful Post: | jsheridan (03-27-2011) |
| Display Modes | |
| Using Aerosol Polyurethane to finish doors? | roxksears | General Discussion | 4 | 11-07-2010 06:16 PM |
| Particles showing through the polyurethane over my newly-sanded hardwood floors | proofer | Flooring | 3 | 12-10-2008 09:42 AM |
| oil vs water poly | batwoman | Flooring | 6 | 09-30-2008 11:00 PM |
| Minwax Polyurethane vs. Minwax Polyurethane Floors | proofer | Flooring | 3 | 04-06-2008 09:48 AM |
| Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? | proofer | Painting | 2 | 04-05-2008 08:47 PM |
