Using A Hair Dryer To Speed Up Curing - Painting - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 11:34 AM   #1
Using a hair dryer to speed up curing
of 1/16" to 1/8" thk spackling that would otherwise take many hours.
Dos and don'ts?
I'm aiming for just enough curing to put a coat of primer on it.
Old 07-18-2012, 11:39 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
It will of course dry the outside first- and might be a problem if you seal it before inside is dry. But it is done that way, or with a fan all the time.
I carry a couple of blower fans and use them to dry stuff almost every day.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-18-2012, 01:49 PM   #3
With just moving air, or heat + air? How long does it take?
This hair dryer thing seems to work well, and if I had real skill I'd use it with hot mud.
I should make holes in scrap drywall chunks and practice, practice, practice.
Old 07-18-2012, 02:11 PM   #4
What are you patching? Usually I have a room, might have a few issues- i mud as needed- put the fan on the worst and go find something else to do.
Much of pro or efficient painting is procedure and timing.
I seldom use a heat gun or dryer.
You make it sound like you have a million holes, and do them one at a time! lol
Old 07-18-2012, 03:23 PM   #5
Gymschu's Avatar
Rewards Points: 842
This would definitely be a time to use some quickset joint compound. Nice thing about it you can mix up just what you need. You could use the 20 minute drying compound and not have to worry about breaking out a hairdryer or fan. There's also something called Water Putty that sets in short order. Spackling is great but not if you're in a hurry for it to dry.
Gymschu is online now   Reply With Quote
Old 07-18-2012, 03:33 PM   #6
(please- no Rock hard water putty..)
Old 07-18-2012, 04:32 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Old 07-18-2012, 05:19 PM   #8
Well, it's two clusters of three half-inch holes but I keep having to go back to the HO for one reason or another. Like, when I leave it looks good and will be ready for priming and when I come back it doesn't look so good.
I may go back to trying hot mud but I will also buy a hair dryer.
They make a good test load for checking household wiring integrity and they're also good for getting a grill going with stubborn or wet coals.
Wet hair? I can live with it.
Thanks, folks. . .
Old 07-18-2012, 05:24 PM   #9
BTW Gym- hot mud sets up quick- but you still cant paint until the moisture is out of it. It's great for getting multiple coats up quick, but you still have to wait..
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
oldpaintdoc (07-18-2012), Yoyizit (07-18-2012)
Old 07-19-2012, 02:44 PM   #10
It worked out very well except for the brush strokes in the Kilz primer. Probably lightly tamping this with a damp rag would have fixed it.
And even though I brought my own, the HO gave me a hair dryer she had no use for. What a day
Old 07-19-2012, 02:52 PM   #11
Gymschu's Avatar
Rewards Points: 842
Originally Posted by chrisn View Post
It is a bi*** to work with, but the idea was to give the poster products that set up quickly.........didn't think standing in front of a patch for three hours with a hair dryer was the way to go when other products set up quicker. Hot mud, sure, you don't want to paint over it right away if you DON'T HAVE TO.....but, in a pinch and in a hurry, well you gotta do what you gotta do.
Old 07-19-2012, 04:48 PM   #12
chrisn's Avatar
Rewards Points: 394
Old 07-19-2012, 05:31 PM   #13
The hair dryer sets up the 24 hr spackling within a minute. You can almost watch it shrink, so you repeat it twice or 3x, then you're done.
I'll have to refine this technique on scrap drywall.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Ceiling Fan trips hair dryer GFCI bigsteve80 Electrical 13 03-26-2012 09:48 PM
Dog hair in the dryer BRIANisMEisWE Appliances 7 12-27-2011 02:18 PM
Hair dryer question Ultrarunner2017 Electrical 27 02-03-2009 09:49 AM
