Using Fiberglass Filler On A Balcony - Painting - DIY Chatroom Home Improvement Forum
Old 12-30-2006, 08:32 PM   #1
Rewards Points: 670
Using fiberglass filler on a balcony
I have a low spots on my decks where I want to divert water to the scuppers during the rains. I have been advised it I could fill the spots up with fiberglass filler. I have two questions.
First, I would be using fiberglass cloth, resin and catalyst as the filler, correct?
Second, I need to fill in at least 1 inch deep. Is this pretty deep for fiberglass? It seems that would be thirty or more layers of fiberglass cloth. That seems awfully messy, and heavy as well.
darsunt is offline   Reply With Quote
Old 12-31-2006, 08:53 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
What's the deck made out of?
I've heard of (but don't use) bondo being used on wood
I use epoxy or wood filler
Composite, I don't know
We'd probably have to move the thread into another section for that
I've never seen, or heard of, fiberglass being used on wood
It really doesn't sound right for your project
slickshift is offline   Reply With Quote
Old 12-31-2006, 08:13 PM   #3
Rewards Points: 670
I posted it in this forum because they sell fiberglass stuff in the paint department at hardware stores. I will try other forums.
The floor of the deck is some kind of waterproof fiberglass. There is a low spot I was hoping to fill.
Fiberglass pools: joasis Building & Construction 5 01-10-2009 05:14 PM
water pressure tanks metal vs fiberglass elementx440 Plumbing 2 04-11-2007 09:50 PM
Pot filler length wbjdmd Plumbing 2 11-09-2006 06:20 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
