Using Exterior Latex On Interior? - Painting - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 01:41 PM   #1
Rewards Points: 334
Exclamation
Using Exterior latex on Interior?
I have a couple of cans of white Exterior Latex that i want to use on some Interior trim. Is there any downside to doing this?
tripower is offline   Reply With Quote
Old 04-18-2010, 02:04 PM   #2
DIY staff
Rewards Points: 7,174
Yes--exterior paint are designed to "chalk off" . You ever notice --when you rub your hand over the siding--you have a little paint dust on your hand?
That is fine outside--the rain leaves the paint looking fresh--not so good inside.(Unless it rains inside your house)--Mike--
Old 04-18-2010, 02:28 PM   #3
(the original)
Rewards Points: 756
Worse.....depending on the paint, you can end up with long term voc outgassing. Don't do it.
ratherbefishin' is offline   Reply With Quote
Old 04-18-2010, 04:10 PM   #4
remodeling pro
I do not know if the exterior paint will chalk off without exposure to the elements, but I agree about the much longer lingering odors. Most decent exterior paints also contain mildewcides from the manufacturer, which you would not want outgassing into your home.
troubleseeker is offline   Reply With Quote
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Basement Wall- Insulate or Ventilate? Rob D. Building & Construction 9 03-29-2009 05:41 PM
soundproofing an interior door mgilliam Building & Construction 8 12-03-2008 12:25 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
