Using Compressor To Paint Trim - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 10:57 PM   #1
Rewards Points: 256
using compressor to paint trim
how well does using an air compressor and a gravity feed gun work to paint trim work ? or is it a waste of time ? im using dutch boy cabinet and trim acrylic latex high gloss ultra white . also what is alkyd low luster enamel satin ? is it a more durable paint ??
oldrivers is offline   Reply With Quote
Old 02-07-2011, 09:34 AM   #2
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
I haven't done this myself, but I've seen it done many times; usually when new floors are also being installed. Nothing beats the look. If I were doing it, I'd put a bead of painters caulk along the top of the trim first. No gaps and no brush strokes.. it looks amazing.
inK
Hammer in Hand, Dad on Speed Dial
http://www.mydadsshoes.com
ink is offline   Reply With Quote
Old 02-07-2011, 12:50 PM   #3
Spray on
Fill the gun's reservoir with paint. Turn on the air compressor and spray a little bit to see how it will perform.
You need to consider that most latex paints are pretty thick, so you might need to thin it quite a bit before hand. Use FLOETROL to thin down the consistency, and never use water because it will compromise the product and make the paint run.
It's a good idea to test spray on some scrap wood to see what you have. "clumpy" and splotchy - the paint is too thick. Lines on the top and bottom of the spray pattern - the paint is too thin.
Try spraying several small coats instead of one large coat. This will help the paint lay out better and look more consistent.
HDPaintPro is offline   Reply With Quote
Old 02-14-2011, 01:16 AM   #4
Rewards Points: 256
well i cant get my compressor to work so i will probably just brush the rest of it .. thanks though.
Old 02-14-2011, 08:01 AM   #5
DIY staff
Rewards Points: 7,174
You would have had trouble,anyway. Latex is usually sprayed with an airless pump---
---The thinning needed for a compressor gun usually is a failure,--Mike--
Old 02-14-2011, 08:11 AM   #6
Gymschu's Avatar
Rewards Points: 460
And, good golly don't use any Dutch Boy paint........just not a high quality paint to use on woodwork.
Gymschu is online now   Reply With Quote
Old 02-16-2011, 07:16 PM   #7
Rewards Points: 256
Heres another question , can you take eggshell paint and make it satin 1 grade higher sheen ? the sample at the store eggeshell looked different than what i ended up with .
Old 02-16-2011, 07:29 PM   #8
DIY staff
Nope--sorry---The most common trim paint is a semi-gloss---Satin has a little less gloss--
If that is the look you are after--you will need to buy the satin.
Old 02-17-2011, 06:44 PM   #9
Rewards Points: 256
ok i went and got a gal of benjamin moore ...
The Following User Says Thank You to oldrivers For This Useful Post:
oh'mike (02-17-2011)
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
