Closed Thread
Old 07-06-2012, 11:48 AM   #1
Using ceiling paint as a dry-wall sealer?
Is ceiling paint the same as dry-wall sealer? Someone told you could use any acrylic paint watered down as dry-wall sealer. But I figured ceiling paint with it's porous finish would provide better grab for the topcoat.
Will it peel off?
I have ceiling paint, don't want to buy something else if I don't need to!
gate28 is offline
Old 07-06-2012, 06:09 PM   #2
paper hanger and painter
chrisn's Avatar
Originally Posted by gate28;959192[COLOR=red
]Is ceiling paint the same as dry-wall sealer[/COLOR]? Someone told you could use any acrylic paint watered down as dry-wall sealer. But I figured ceiling paint with it's porous finish would provide better grab for the topcoat.
Will it peel off?
NO
Bad advise
Wrong again
Maybe
Go out and get a proper primer and do it the right way. Why take the chance to screw it up. How much will that then cost you to rectify?
chrisn is offline
Old 07-06-2012, 06:17 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
One of my fav sig lines someone around here has
If you don't have time to do it right the first time, when will you have time to fix it?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline
Old 07-07-2012, 03:16 AM   #4
I found out that ceiling white and broadwall sealer are very similar. Ceiling white usually has more base pigment than sealer, but then sealers that cover as well as seal (which most people seem to think equates to a better seal) are pretty much what a super flat white ceiling paint is.
Paint companies are keen to sell you a different product for every stage of a job. I watered down some ceiling white and gave it two coats. A light sand and two top coats. Perfect.
Compared to Consumer ranges - those same companies have a very limited trade range - ie thats all you need.
gate28 is offline
Old 07-07-2012, 04:20 AM   #5
chrisn's Avatar
What was the reason for the first post?
chrisn is offline
Old 07-07-2012, 07:03 AM   #6
Q. 1. Will ceiling paint peel off dry wall?
Q. 2. What is the difference in composition between ceiling paint and dry wall sealer?
gate28 is offline
Old 07-07-2012, 08:32 AM   #7
Ceiling and sealing are too way different things.
One you look up at, dont touch, dont have dogs and kids brushing against. So a paint for it can be very flat and very porous.
A primer that seals the walls actually seals the walls. It makes them not porous so the top coat doesn't get the life sucked out of it by the drywall and the wall has even porosity.
Old 07-07-2012, 01:05 PM   #8
sdsester's Avatar
You seem intent on doing what you want and arguing with sound advice from some of us who have been at this professionally for a long time. Sealers, primers and paints are not the same thing. But go ahead and play your trump card and hope for the best. Oops. You already did so your question is rather irrelevant at this point?
sdsester is offline
Old 07-07-2012, 02:57 PM   #9
In my case, sealing dry wall with ceiling white was the way to go. It worked fine. And didn't cost me any more money.
Cheers
gate28 is offline
Old 07-07-2012, 03:20 PM   #10
the Musigician
DangerMouse's Avatar
You COULD use brown water from your toilet to prime with, as to whether or not it's a good idea is debatable.
Thread closed.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
DangerMouse is offline
The Following User Says Thank You to DangerMouse For This Useful Post:
chrisn (07-07-2012)
Closed Thread
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 05:28 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
