Using Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 04:40 PM   #1
using ceiling paint
can I use a ceiling paint for a primer on my walls, will it cover as nice as it does on the ceiling?
Humm is offline   Reply With Quote
Old 05-31-2011, 05:34 PM   #2
ltd
Rewards Points: 536
what is on your walls now
ltd is offline   Reply With Quote
Old 05-31-2011, 05:47 PM   #3
Gymschu's Avatar
Rewards Points: 486
I have done it in the past w/o any problems, but, I would rather use a primer on new drywall. Just a purist I guess. The main reason I did it was because I had so much ceiling paint leftover from another job and I wanted to use it up.......so, yes, I used it as primer.
Gymschu is online now   Reply With Quote
Old 06-01-2011, 05:47 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
CAN you, yes. SHOULD you, no.
chrisn is online now   Reply With Quote
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 05:28 PM
Ceiling hairline Cracks and New Paint sw8689 General DIY Discussions 9 11-11-2009 12:43 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
