Using Caulk Instead Of Tape On Hairline Cracks.. - Painting - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 12:59 PM   #1
Rewards Points: 179
using caulk instead of tape on hairline cracks..
I know the caulk question comes up often here, and i know that mud and tape is the best policy, but i have a limited amount of matched paint and doing a tape job would require too much paint to cover.
I have a metal corner bead that has "moved" a millimeter enough for a hairline to form the entire length. i know i cant just mud it again i'm experienced enough to know it will crack again. If i tape it now we're talking about 6 inches wide at least of paint needed to cover. (floor to ceiling)
Can caulk put over the crack, (smoothed with finger, then wait a day) then covered in mud, hold over time? i was hoping the little bit of flexibility in the caulk would hold the hairline crack over time.
Believe me, i'm not so lazy that i don't want to tape it, i love to spackle, its totally a paint matching issue i figure i only have to paint 3 inches wide with caulk instead of 6 inches wide with tape and i only have a small amount of leftover paint to match.
windowguy is offline   Reply With Quote
Old 04-15-2009, 07:08 PM   #2
Drywall contractor
Rewards Points: 1,070
As you said, it will crack again. The caulk will probably work, but I doubt for very long. The bead actually needs to be nailed back down. As you nail it, it may continue to crack further (and on the opposite side), but once it and the drywall underneath are tight to the framing again, it should be fine. If you're expecting it to last for years, not likely, but you never know...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-15-2009, 10:27 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Ya give the caulk a try. Let it dry 24 hrs before touching up with the paint.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Repairing Hairline Cracks in Plaster Walls jerome8283 Painting 8 11-17-2011 07:43 AM
Window Glazing - hairline cracks bill3752 Painting 3 10-03-2008 11:15 PM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 05:30 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
