Using BIN Shellac Base Primer Sealer - Painting - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 01:01 AM   #1
Rewards Points: 81
using BIN Shellac Base Primer Sealer
Hello, I'm getting ready to primer some wood paneling in my family room and have read some excellent advise that I should use BIN Shellac Base Primer Sealer. I got some and was reading the directions where it talks about using a brush, roller and then about spraying it on. Right after this it mentions using a NIOSH approved respiratory protection, etc. My question is, is that only necessary if a person sprays it or should I even get one a NIOSH approved respiratory if I plan to brush it on? Also, can anyone recommend a good NIOSH approved respirator? I've seen a 3M product but don't know much about em. Thank you, Joe
joefromcal is offline   Reply With Quote
Old 05-02-2009, 01:40 AM   #2
BIN is good stuff. I rolled BIN in my entire kitchen because of some stubborn grease stains that were trapped behind joint compound. (the guys who replaced a segment of the drywall didn't clean the other areas before they taped the seams) I didn't use a respirator and I was fine. The fumes from the ammonia that I used to clean the brushes was far more stronger than BIN.
Oh and BIN got the job done. Blocked grease stains...thats good BIN.
In my newbpainter opinion, I would say if its only a one weekend thing, you'll be fine without a respirator.
newbpainter is offline   Reply With Quote
Old 05-02-2009, 02:16 AM   #3
Originally Posted by fast1 View Post
how much is it and where can i get a good price for it?
It's available at most paint stores and most big box stores. I know homedepot carries it. Less that 20. What do you plan on using it on?
Old 05-02-2009, 05:34 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
It's your brain cells that will be destroyed if you don't, use a respirator! You can usually get them right with the painting supplies.
chrisn is online now   Reply With Quote
Old 05-02-2009, 12:15 PM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
BIN is one of the more potent items on the market. Thankfully the fumes dissipate quickly. You should be fine without the respirator if you have very good ventilation. Let those fumes build up even a little though and be dizzy within minutes.
poppameth is offline   Reply With Quote
Old 05-03-2009, 03:31 AM   #6
Rewards Points: 81
Thank you all for the responses.
Old 05-03-2009, 05:09 AM   #7
chrisn's Avatar
Rewards Points: 124
Guess what that means? Dizzy = get respirator
Old 05-03-2009, 12:01 PM   #8
Rewards Points: 81
chrisn,
Thanks for the input. Yeah, I prefer not to take chances. I'm gonna get me a respirator. Thanks again.
Old 05-03-2009, 12:18 PM   #9
Rewards Points: 1,528
The vehicle in this has alcohol and that is the issue. If windows are kept open you'll likely be ok with some good ventilation. Otherwise you need an organic filter in the respirator as per:
http://www.zinsser.com/pdf/MSDS/_bin_ms.pdf
bob22 is offline   Reply With Quote
Old 05-03-2009, 12:28 PM   #10
(the original)
Rewards Points: 756
I always brush and roller BIN. If I was gonna spray it I think I'd want a full dive suit Those alcohol fumes can get to you in a hurry, and it's a skin irritant, too. I always create cross ventilation as best I can and put a fan in front of a window to exhaust the fumes. The 3M #8577 mask, rated for nuisance level vapors, works fine in that situation. If I can't properly ventilate a room, then I go to my respirator.
ratherbefishin' is offline   Reply With Quote
Old 05-04-2009, 06:47 AM   #11
chrisn's Avatar
Rewards Points: 124
Tags
bin , niosh
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Primer Sealer Oil or Water Based? petey Painting 7 05-11-2008 07:11 AM
Zinsser Bulls Eye Water Base Primer helpless handyman Painting 2 10-13-2007 11:05 AM
