Hello, I'm getting ready to primer some wood paneling in my family room and have read some excellent advise that I should use BIN Shellac Base Primer Sealer. I got some and was reading the directions where it talks about using a brush, roller and then about spraying it on. Right after this it mentions using a NIOSH approved respiratory protection, etc. My question is, is that only necessary if a person sprays it or should I even get one a NIOSH approved respiratory if I plan to brush it on? Also, can anyone recommend a good NIOSH approved respirator? I've seen a 3M product but don't know much about em. Thank you, Joe
BIN is good stuff. I rolled BIN in my entire kitchen because of some stubborn grease stains that were trapped behind joint compound. (the guys who replaced a segment of the drywall didn't clean the other areas before they taped the seams) I didn't use a respirator and I was fine. The fumes from the ammonia that I used to clean the brushes was far more stronger than BIN.
Oh and BIN got the job done. Blocked grease stains...thats good BIN.
In my newbpainter opinion, I would say if its only a one weekend thing, you'll be fine without a respirator.
BIN is one of the more potent items on the market. Thankfully the fumes dissipate quickly. You should be fine without the respirator if you have very good ventilation. Let those fumes build up even a little though and be dizzy within minutes.
The vehicle in this has alcohol and that is the issue. If windows are kept open you'll likely be ok with some good ventilation. Otherwise you need an organic filter in the respirator as per: http://www.zinsser.com/pdf/MSDS/_bin_ms.pdf
I always brush and roller BIN. If I was gonna spray it I think I'd want a full dive suit:laughing: Those alcohol fumes can get to you in a hurry, and it's a skin irritant, too. I always create cross ventilation as best I can and put a fan in front of a window to exhaust the fumes. The 3M #8577 mask, rated for nuisance level vapors, works fine in that situation. If I can't properly ventilate a room, then I go to my respirator.
I have used Bin shellac multiple times inside without a respirator. I open windows, turn on house fan and place a box fan in window or open door for cross ventilation. I have never been dizzy or negatively affected. That said, it’s probably a good idea to use one. I strongly agree with the comment regarding the ammonia used to clean brushes/roller covers being far stronger irritant than Bin. Therefore, plan on using disposable supplies. That’s the best recommendation I can give you. But have denatured alcohol available while painting. I use it regularly to dip my brush or roller because the shellac will become thick and sticky during use.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
