Using Behr Stain ? - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 05:46 PM   #1
Rewards Points: 127
Using Behr stain ?
I just purchased a 5 gals of Behr acrylic wood stain/waterproofer. It will be used to stain my privacy fence. Should I return it and get an oil based stain? Also, how long should I let the wood dry after a rain? 24 hrs? The wood has never been treated and is a little over a year old.
Thanks!
wkumtrider is offline   Reply With Quote
Old 06-20-2010, 06:04 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Thanks!
If you are using a solid or semi-solid on the fence I would use an acrylic latex, if its a translucent I would use an alkyld, a fence and a decks walking surface are totally different, a quality acrylic stain will retain the color better, mildew resistant, and will fade slower, I have seen acrylic deck stains last just as long as oil base deck stains, most decks that I've seen an acrylic stain on it is only the walking surface that's wore, but that will happen with any stain, proper prep is key and a lot of people don't realize what proper prep for deck staining is, its more than just washing the deck, its using the right cleaners, stripping if needed, neutralizing any strippers used, brightening, and sanding as needed. Personally I wouldn't use bear paints or stains for anything.
housepaintingny is offline   Reply With Quote
Old 06-20-2010, 06:10 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Thanks!
Are you kidding? YES
Shoe polish would work beter.
chrisn is online now   Reply With Quote
Old 06-20-2010, 07:22 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Yup
Yup
slickshift is offline   Reply With Quote
Old 06-23-2010, 09:44 PM   #5
Rewards Points: 127
I will return it and plan to get Cobat stain from Lowe's. Hopefully that will be ok.
Old 07-04-2010, 01:53 PM   #6
Behr failed in months!
I purchased the Behr Premium stain for my deck (in Indiana) and applied it two years ago in the fall. The stain did not make it through the winter and began peeling badly by spring. I went back to the store where I purchased it to complain. I showed them pictures and their response was that I had obviously not applied it correctly. I then proceeded to follow their instructions to the letter to reapply the same stain (obvious learning disability). I sanded the deck, cleaned it with their specified product and reapplied with a special brush. One year later I am right back where I started. At the same time that I applied my Behr Stain I used Olympic on my Mothers deck. I tried to convince her that the "premium" stain would be better but she told me that my father swore by Olympic and she did not want anything else on her deck. Her deck still looks great and mine will be redone for the third time in three years. BTW, I will be using Olympic.
Buzzkill is offline   Reply With Quote
Old 07-05-2010, 10:30 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
THIS is why you don't use Latex Deck Stain
Old 07-05-2010, 01:39 PM   #8
Rewards Points: 271
As the one fellow said - Olympic is good. Lowes and others sell it. I was in Lowes and I think they had a sale for the 4th weekend. I have used Wood RX (acrylic) in a hot sunny climate. People who use it in the area like it.
Frank Lardino
FrankL is offline   Reply With Quote
Thinking of Behr Premium Plus deck/fence stain - good? curls00 Painting 77 07-31-2012 05:36 PM
So how do we fix this mess!!! BEHR Stain peeling FMJB Painting 15 09-26-2011 09:18 PM
Behr Latex Stain loyal Painting 17 04-19-2011 08:11 PM
Behr Quick Fix Deck Stain Remover mahjohn General DIY Discussions 1 12-04-2007 11:39 AM
