Use A Foam Brush To Touch Up Some Trim With An Oil Base Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 09:39 AM   #1
Question
Use a foam Brush to touch up some trim with an oil base paint?
Can I use a foam brush to touch up some interior trim with an oil base paint?
Dennis
djtjak43 is offline   Reply With Quote
Old 03-01-2009, 12:28 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
You can...but it will not look nearly as good as if you used a china bristle brush
Although technically you can apply oils with a foam applicator, it's hard to blend and feather the touch-ups
It's much easier to feather the touch-ups, and have them blend in, with the proper brush
Depending on how much needs touching-up, it may be better to coat whole sections, from natural break to natural break
slickshift is offline   Reply With Quote
Old 03-01-2009, 03:49 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
What slick said.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Reptile Cage Finished Marc10edora Project Showcase 21 11-16-2010 05:20 PM
Any good tops for keeping paint from drying on the sides of the brush? Jim S. Painting 16 02-13-2009 02:18 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Can you use canned spray paint for trim? tomatolater Painting 2 04-08-2008 11:10 AM
