Old 08-17-2010, 07:41 PM   #1
Question
US ban on oil based paints in 2011?
Local paint dealer claims no more oil based finishes as of jan. 2011, Googled this with no results. Need to coat new wood risers on a staircase and oil based clear coat would be my choice. But if not able to recoat when necessary with similar product, than maybe water based best alternative now?
Mi Feller is offline   Reply With Quote
Old 08-17-2010, 08:00 PM   #2
Chicago, IL
Michael Thomas's Avatar
Likely, the dealer was referring to the tightened standards for VOCs in general, see for example:
http://www.oldhousejournal.com/magaz...int-regs.shtml
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
Mi Feller (08-18-2010)
Old 08-17-2010, 09:29 PM   #3
jce
Yeah , I work for a paint company & there is no ban yet planned. maybe in the future there will be something , but like they said probably referring the the new voc regulations.
jce is offline   Reply With Quote
The Following User Says Thank You to jce For This Useful Post:
Old 08-18-2010, 06:53 AM   #4
Doer of Many Things
poppameth's Avatar
I hear this every year. So far the manufacturers and end uses have complained enough to keep it from happening. Keep in mind also that the US government has no such regulation for their own use and often insists on some of the most volatile mixtures I've ever seen in a spec.
There are acrylics out now that do a pretty good job bonding to old oil and oil/water hybrids are popping up as well. The real problem is exterior work. When you have expansion/contraction issues to deal with as well, the best acrylic can still cause issues over oil.
poppameth is offline   Reply With Quote
Latex over alkyd primer TVC15 Painting 15 08-15-2010 12:42 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint sticking at door/jamb Corcoran1 Painting 10 06-20-2008 08:03 AM
