Old 09-11-2014, 11:55 AM   #1
Share |
Urgent! run into problem on paint basement concrete floor
Hi,
I tried to paint basement concrete floor, but run into problem.
The original concrete floor is bare. There are some tiny crack, so builder put some sealant on it (confirmed it is paintable).
Then I paint latex paint on it. But the new paint did not cover the existing sealant, but make the sealant color more sharp.
Can anyone give some idea how to fix the problem? Thanks in advance!
The pictures have been attached.
Thanks!
Urgent! run into problem on paint basement concrete floor-1_basement_floor_with_sealant.jpg   Urgent! run into problem on paint basement concrete floor-2_armor-coat-latex-paint.jpg   Urgent! run into problem on paint basement concrete floor-3_after_apply_latext_armor-coat-latex-paint.jpg
newhome7777 is offline   Reply With Quote
Old 09-11-2014, 12:34 PM   #2
Jmayspaint's Avatar
Put more paint on it. If by 'covered' you just mean uniformity of color, them it just needs another coat or a thicker coat or both. What you are seeing is just the color of the sealant bleeding through the paint. It will cover once the paint film is thick enough. Colors like that Orange are hard to get to cover an often take multiple applications.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Danahy (09-11-2014), ToolSeeker (09-11-2014)
Old 09-11-2014, 05:17 PM   #3
paper hanger and painter
chrisn's Avatar
[QUOTE=Jmayspaint;1401696]Put more paint on it. If by 'covered' you just mean uniformity of color, them it just needs another coat or a thicker coat or both. What you are seeing is just the color of the sealant bleeding through the paint. It will cover once the paint film is thick enough. Colors like that Orange are hard to get to cover an often take multiple applications.[/QUOTE]
probably 4 or 5 looking at the first one
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (09-11-2014)
Old 09-13-2014, 10:37 AM   #4
Thanks Jmaypaint and Chrisn,
Just wonder, is it OK to I put different color,m such as grey, on second round? Which will be on top of the color of orange.
And, would you please let me know any possible stronger paint to cover that orange color?
Thanks!
Old 09-13-2014, 05:09 PM   #5
chrisn's Avatar
As long as they are both latex, you can put ant color on top of the orange
How to remove paint stripper from concrete floor elyders Concrete, Stone & Masonry 7 06-10-2013 07:24 PM
Concrete basement floor paint RCGA Painting 16 04-22-2013 11:32 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Concrete in basement laundry/furnace room looks horrible - paint???? simiesue Flooring 4 11-15-2011 10:46 AM
Need to paint concrete basement floor tristar76 Painting 4 08-22-2009 06:57 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
