Urethane Finish - Painting - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 05:29 PM   #1
Question
Urethane Finish
My second coat of Helmsman Spar urethane dries dull. I sanded it after setting overnight. It is a satin finish, but looks much duller than the first coat.
dave12 is offline   Reply With Quote
Old 02-09-2011, 06:58 PM   #2
DIY staff
Rewards Points: 7,174
Did you stir the can frequently as you worked? There is a clouding agent in a satin finish--this tend to settle as you work---if not stirred regularly the clouding effect gets worse as the can gets used up.
dave12 (02-11-2011)
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
