Old 08-02-2007, 06:55 AM   #1
unsticking an airless paint sprayer
I have a Campbell Hausfeld 1/2HP airless paint sprayer. I had used it for years and then it sat for a while. I went to use it again and it didn't have the suction. I replaced the diaphram part of the vacuum and it still won't suck...even water.
What can I do to really clean the inside of the sprayer to get it back to good working condition. I was told way back when I first had it to use Zylene to dissolve all the years of crap the dried in there.
Some tips on keeping it in good condition would be helpful.
thanks.
chrisusvi
chrisusvi is offline   Reply With Quote
Old 08-02-2007, 11:07 AM   #2
SgtBaldy's Avatar
I used to use a CH way back when. There was a little ball in the siphon valve that used to stick shut so it wouldn't prime. You could manually stick somethin in there and unstick it or give the pump a couple of lite taps with a rubber mallet to loosin it.
The best thing to do is take it in to be serviced and cleaned and then start doing a better job of cleaning and maintaining it.
SgtBaldy is offline   Reply With Quote
Old 08-02-2007, 02:20 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
All airless sprayers need maint. after X amount of hours anyway (X depends on the quality of sprayer, cheaper ones after much less than high quality ones)
If yours hasn't reached X yet, it's still been sitting
Time to take it in
slickshift is offline   Reply With Quote
Old 08-02-2007, 10:38 PM   #4
Workaholic's Avatar
Good storage practices, and regular maintance is important with all tools and most especialy for airless sprayers.
Often the ball gets stuck and as suggested a tap with a rubber mallet will unstick it. Some times you will need to take apart the suction tube to get them unstuck. There are 2 small metal balls in an airless that can get stuck. You should probably take it in to be repacked by a spray shop. I would normaly suggest doing this yourself.
I do pretty much all the service on my spray rigs, but i have never seen a repack kit for a CH, i am not saying that they are not out there, i am sure they are i just never come across them because i do not use CH's
Just about any spray rig can be built back to new, though you could probably get another CH much cheaper than the service.
As far as good storage goes, some paint thinner or some pump armor in the pump during storage is your best bet. You never want to have water sitting in your pump during storage. Rust.
Sean
Workaholic is offline   Reply With Quote
Old 08-04-2007, 02:14 AM   #5
747
registered
747's Avatar
if i had a sprayless rig after painting with it i would run some denature alcohol through it.
747 is offline   Reply With Quote
Old 02-24-2008, 02:59 PM   #6
She'sapainter
Some of us painter get really tired after a long job however a spray rig to me is like my auto It's my money maker.
Always clean I can never express this enough however I would suggest running anti freeze in your rig if it's going to set more then a few weeks believe it or not.
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-25-2008, 05:58 AM   #7
Memory serves me right that "Check Ball" is made of plastic.If it gets even the slightest pitting it will keep the siphon from happening.As stated above "Clean & Maintain"
mark942 is offline   Reply With Quote
Old 02-25-2008, 10:34 AM   #8
She'sapainter
Try Anti Freeze in your rig during storage...I thought It was crazy at first but it helps and does not dry out the seals and rest of the innereds
More On This Topic
When you take on the job of painting your home, inside or out, the job can be made easier if you have the right kind of equipment. A paint sprayer can make the job go faster. There are different types to choose from. Read More »
Assembling a Lawn Sprayer
Assembling a Lawn Sprayer by Expert Village
We're talking today about hand sprayers, compression hand sprayers that are used to apply to all kinds of liquid sprays to all kinds of surfaces. This particular one come in a box and has all the necessary parts for quick assembly. It's a handle to carry... Read More »
Pressurizing a Lawn Sprayer
Pressurizing a Lawn Sprayer by Expert Village
We've got our pesticide in the container in the right mixture. We're going to compress the air. And that's done by pumping this handle up and down. Each time you come up it charges with air and when you push it down it puts it into the tank without... Read More »
In this segment we're talking about simple application equipment. Lot of hand sprayers and a lot of equipment that you use. You have to know how much chemical to mix in a gallon, then try to distribute the mixture over a certain number of square feet... Read More »
Okay, I'm ready to get, ready to spray tan. So the first thing I want to do is put gloves on because I do not want this on my hands. I cannot do this with barrier cream on my hands. So I'm going to wear gloves. The next thing you want to do is check your... Read More »
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
paint sprayer elementx440 Painting 5 05-03-2007 04:43 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 02:21 PM
I need a few tip's for airless paint sprayer Doug Crf Painting 1 04-06-2006 08:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
