Unheated Garages: Interior Or Exterior Wall Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Poll: Should interior or exterior paint be used on unheated interior garage walls?
Poll Options
Like Tree1Likes
Old 12-04-2012, 08:17 AM   #16
Rewards Points: 386
Originally Posted by jeffnc View Post
Which is exactly why I wouldn't put flat paint in a garage to begin with - I'd use eggshell (or "matte" at a bare minimum). So the poll ought to be eggshell interior vs. exterior. That makes it a lot closer in terms of performance.
But it does raise the question of comparing apples to apples. If you really want a true flat finish in your garage, then you should use interior paint. You might want that purely aesthetically. Or, you might prefer touching up over cleaning, where flat has an advantage.
Other than that, I guess my next garage will be painted with exterior paint.
Bear in mind that in my original post, I did say I'd recommend the exterior route - for all the reasons listed so far from each responder...Most of my comments then regarding the use of flat paints or interiors is largely to generate discussion of why we'd recommend either and what arguments we'd have to back up either suggestion.
Perhaps when describing option #3 "Situation", I should've compared Aesthetics versus Utility (rather than lifespan). From a utility perspective, flat paints would be the worst recommendation, yet that's what I've painted my garage with...Why? Laziness, I s'pose. In my man cave/workshop/den of solitude & solace (otherwise known as my garage), I can admit that in my 26 years in this house I now reside, I've never once taken a rag to the walls in the feeblest attempt to clean 'em (and I don't think I'm alone here)...I just paint over 'em without any surface prep. Again, why? Because I can - and I am very well aware of possible consequences - as well as whatever corrective measures are necessary in the very real probability that those particular consequences will come to life.
But here's the difference...I would never, ever recommend my system to anyone who actually has to purchase their own paint, especially if they have any kind of performance expectations. And we're really speaking from 3 different perspectives here...(1) what would you recommend to a homeowner doing their own work (as has been posted here many times), (2) what would you, as a professional, recommend to the homeowner that has contracted your services with expectations of a better job than he/she could do themselves, and (3) (and be honest here) what would you do in your own garage?
From perspective #3, I've already told you what I do...and from #2, I absolutely, whole-heartedly agree with JSheridan - that, as a professional, if I am putting my name (signature) and reputation on this agreement, then I absolutely must focus my priorities to first address the performance and utility issues - with aesthetics being secondary...To address perspective #1 - rather than attempt to pound square pegs into round holes with what you think may be best, it's necessary to determine what is the desired objective of that particular homeowner or DIYer before making a final recommendation.
In other words, neither system is necessarily right or wrong - both (either) would work, but each will provide somewhat different outcomes.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
jsheridan (12-04-2012)
Old 12-04-2012, 05:18 PM   #17
Rewards Points: 4,796
Yup.
It probably should be in a FAQ here.
jeffnc is offline   Reply With Quote
Old 03-27-2016, 08:38 PM   #18
Rewards Points: 666
Re: Unheated Garages: Interior or Exterior Wall Paint
I am looking at using SW interior eggshell on my unheated garage walls? What opinions does everyone have on using this? Good/bad? Does it really matter either way? Interior/Exterior?
Also, the walls have are textured. What type of roller should I use that will allow me to get in the textured areas?
kennykenny is offline   Reply With Quote
Old 03-27-2016, 09:19 PM   #19
Rewards Points: 5,974
I don't think the interior/exterior makes that much diff. and it depends on what texture is on the walls as to what nap roller. orange peel 1/2", knock-down 3/4" up to 1 1/4" depending on how heavy the texture is.
Entering your general location can help with answering a lot of times
Old 01-16-2017, 07:08 PM   #20
Rewards Points: 6
My vote is for exterior, it just makes sense. Both because if you leave the garage door open...for whatever reason, and for whatever season you are in....indirectly it will be exposed to some parts of the outside elements. And as one earlier poster said, it's not a big increase of cost, if any at all, so why not. Heck you can even wipe that "OOPS" off the wall before the wife gets home.
reanman is offline   Reply With Quote
Old 01-17-2017, 08:48 AM   #21
Gymschu's Avatar
Rewards Points: 658
This old thread reminds me that Joe Sheridan no longer posts on here. He was a great contributor to the painting forum.
Giving us your general location helps us better help you!
Old 01-17-2017, 10:40 AM   #22
78Vette's Avatar
Rewards Points: 540
The humidity in both heated and unheated Garages will be high enough to justify Exterior Semi. That said, i used Interior Semi (simply because i had lots on hand i wanted to use up) in my own heated Garage/Shop and i keep the humidity in the 40% range.
78Vette is offline   Reply With Quote
Old 01-17-2017, 01:03 PM   #23
Rewards Points: 666
I ended up using SW Superpaint Interior Satin on my garage walls. Got a GREAT DEAL on a 5-gallon bucket. The paint has worked out excellent. No problems, with great coverage.
Gymschu likes this.
Old 01-17-2017, 02:49 PM   #24
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Exterior semi-gloss or high gloss.
Much easier to wash down and saw dust, or any dirt for that matter will not stick to it as well as a flat or egg shell finish
Unheated Garages: Interior or Exterior Wall Paint-dscn7363.jpg
Old 01-17-2017, 04:41 PM   #25
Rewards Points: 6
I have 2 full unfinished walls in my garage, basically the exterior walls that ARE the sides to my 3 car garage. I'm wondering if I'd be best to finish it off with plywood and insulation or drywall?
I don't need a high end finished look, but more of a finished look while keeping it durable is ideal. It's a nice garage, but a garage at the end of the day.
Aaron1085 is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
