Uneven Stain? - Painting - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 09:01 AM   #1
Uneven stain?
I recently built a pine farmhouse table.
I sanded it, beat it up, made it pretty rustic looking. Stained it, looked awesome.
However, I put a coat of clear satin poly on it last night, and in certain spots its shiny, and certain spots its rough and dull.
Is this just becuase its a first coat? Or did I do something wrong?
Mandie is offline   Reply With Quote
Old 06-11-2012, 02:07 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
everything is cool. The finish ( not the stain) is getting sucked into the soft grain of pine, and not into the hard grain.
This always happens on the first coat. Sand smooth - use a fine sanding sponge or 220 grit paper, clean dust off and give it another coat.
For a table I would do this twice- for a total of 3 coats.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
oh'mike (06-11-2012)
Help, removed carpet running and stain is uneven! Jocrazy Flooring 3 05-29-2012 08:24 PM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 10:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 05:51 AM
