Uneven Painti - Painting - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 11:03 AM   #1
uneven painti
I've recently painted and did the ceiling trim where the wall and ceiling connect. I Painted that last and now the trimming is uneven with the color of the wall. I used two coats for the walls and trims. How can I fix it? Thank you
davegonzo is offline   Reply With Quote
Old 02-17-2011, 01:11 PM   #2
Khaki Pants
Do you have a picture you could post?
xraypaint is offline   Reply With Quote
Old 02-17-2011, 01:19 PM   #3
No I don't have a picture. The trimming is a lighter color then the actual walls. Would I have to repaint the whole walls again?can I send u a picture to your email. I can't post them thru my phone. But I can send u one thru my email.
Old 02-17-2011, 03:17 PM   #4
Rewards Points: 150
Probably due to the underlying paint color/sheen I vote for one more coat on the trim.
STL B. is offline   Reply With Quote
Old 02-17-2011, 07:21 PM   #5
Dave, when you say "trimming", do you mean the cut in, where you painted the wall color with the brush? If so, it sounds like you might have "hatbanding", which usually occurs with certain colors like golds and greens. It's usually, in my experience, when I use Ben Moore products. The texture of the brush versus the rolled sections reflects light differently, and is highlighted in certain colors. Chat rooms are filled with tips for combatting hatbanding, but there is nothing. You could dutch roll, horizontal, up as close to the ceiling as you can. That's crazy and could turn an eggshell or satin wall into a mess worse than the hatband. Since I can't beat it, I join it. I just roll normally up as close as possible, without hitting the ceiling, and keep that line even at the top and bottom and in the corners. It's worse if your stop line is zig-zag. And, you did the best you could to reduce the unsightliness of the condition. PM me if you would like some tips on keeping the line close and even without hitting the ceiling. I have a pretty neat trick.
Old 02-18-2011, 01:20 PM   #6
Khaki Pants
If you would like to send me some pictures here is my address: dugs1212@gmail.com
Tags
paint interior house
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Uneven Floor Problem JasonP2010 Flooring 1 06-09-2010 03:10 AM
Uneven ceiling dudepigeon Carpentry 3 07-08-2009 12:13 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 03:20 PM
