#1 |
uneven paint. help
Hi all,
thought someone here might know how to help. I had my first attempt at painting this weekend and thought did a fair amount of research on the web. It was a lot harder and more work than I expected. My biggest problem is that the paint looks uneven. I painted a honey brown/orange color and some parts are browner and other are oranger. the interior wall has a medium texture to it. I cleaned the walls w/ TSP and painted w/ Behr water based paint using a 3/8 9 in. roller and trim roller. Is it possible to fix this w/out having to sand and repaint the whole thing. Can I just add another coat to the brighter spots and try to blend it in. thanks |
#2 |
Painting Contractor
uneven paint. help
I don't think you need to sand, you can probably get away with just putting on another coat. I have had the misfortune of working with Behr paint and it doesn't have very good covering/hiding qualities.
Without seeing it, it sounds like you have lap lines. Lap lines form on a wall/ceiling when you let an area dry somewhat before continueing painting. You only have a window of about 5-20 minutes with most interior paints with a 2-4 hour drytime before you loose your wet edge. If this sounds like the case you could try buying some "stay open" or Floetrol and adding it to the paint. Both of these make the paint dry slower. Or you could get a helper to roll while you edge or vice versa, and work fast, only stopping when you have reached the end of a full section of wall.
Bliss is a fresh piece of sandpaper. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
uneven paint. help
Here's a picture of the wall. Are these laplines? sorry picture is small but the file size limit is pretty low. but you can see some slight discoloration and variation in color.
#4 |
Painting Contractor
uneven paint. help
I can't tell from that picture. I do see some light spots...
Can you e-mail me the picture at a higher resolution? humbleabodellc@excite.com
#6 |
Paperhanger/painter
uneven paint. help
I copied the pic and blew it up. I see the problem, and have the solutions.
A. Trash the 3/8" nap, and get a 3/4" nap. B. Trash the Behr, and get some real paint. C. Apply another coat or two.
ProWallGuy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 | |
uneven paint. helpQuote:
#8 | |
Painting Contractor
ProWallGuy is right on. Bennjamin Moore is great Sherrwin Williams is good too, hell even Mautz is better than Behr. If you take your sample into any of those they will be able to match the Behr color exactly.
#9 |
Contractor
uneven paint. help
FYI, most paints won't cover in just one coat unless it's sprayed. Go to 2 coats and your problems should be over. Also don't try and stretch the paint, a lot of people try to get the max out of the can and apply the paint too thinly. Practice makes perfect.
#10 |
uneven paint. help
It almost looks like you have a faux finish goin on there. I agree with everyone else about Behr paint. Less forgiving than others. I prefer Bennjamin Moore myself. I've learned after a few subpar paint jobs years ago that as soon as your done painting about a 3 foot wide area go back over it top to bottom never letting the roller leave the wall while gradually moving over after every stroke. Comes out even every time with no dark or light spots regardless of the color. Almost looks like i know what i'm doing. Someone metioned about stretching the paint too. Unless your painting the inside of a closet this is not recommended. 3/4" nap good idea.
#11 | |
Tired, Cold, and Damp
Two coats of benny Moore and you'll be fine |
#12 | |
Don't chince out on the roller sleeve, that can make a big difference Get a good one (I like Purdy) with a bigger nap |
| Display Modes | |
| Vinyl Paint - PolymatrX - and Siding.... | Classic | Painting | 2 | 07-23-2008 07:45 AM |
| SW Duration paint - OK to thin with water? | plin321 | Painting | 10 | 08-11-2007 10:29 PM |
| Paint coming off of siding | ciera | Painting | 5 | 07-01-2007 06:22 PM |
| exterior paint question | sherlock | Painting | 5 | 07-05-2006 08:31 AM |
