Uneven Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 06:51 PM   #1
uneven paint
I am painting a deck surface for my brothers wedding. I have used a latex based primer and a dark custom exterior latex color. The deck has 3 coats on it and it is still uneven. You can see where the roller starts and stops, even if the roller has plenty of paint on it. I have painted before and ever had this problem. What could it be?
kac3693 is offline   Reply With Quote
Old 10-31-2010, 07:58 PM   #2
jschaben
Rewards Points: 502
Hi - Welcome to the forum
I think we need a lot more information to be of any meaningful help. What is the deck made of? has it been painted or stained before? Is it fairly new? Doesn't sound like you used a porch and floor paint which will give you problems down the road, but they should apply OK, just peel off later.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-31-2010, 11:26 PM   #3
Faron79's Avatar
Rewards Points: 260
2 Questions....
1) Why did you prime the floor?!
2) What EXACT paint/brand/series was used??
By priming the floor, you've just prevented what deck stains are supposed to do....PENETRATE.
Plus...There are VERY FEW primers for horizontal surfaces!
Faron
Faron79 is offline   Reply With Quote
Old 11-01-2010, 03:37 PM   #4
Handyman
Rewards Points: 512
Whenever I paint large areas I always run the roller past my stop point with a light stroke. Stopping a roller leaves a thicker paint residue which essentially can create a line of 3 or 4 coats. Bad rollers can leave lines with the same effect and also need to be feathered out. On drywall applications you can correct this with a slight skimcoat of DW compound...not sure what to do with a wood deck other than sanding those spots with a belt sander
canadaclub is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
