Uneven Ceiling Joint/lines - Painting - DIY Chatroom Home Improvement Forum
Old 06-27-2009, 03:22 PM   #1
Uneven ceiling joint/lines
It has come to my attention that a few of our walls ceiling lines are not striaght. There is a little dip in the line for about 18 inches. (It sags a bit to the left of the speaker) Then it comes back up to meet the adjoining wall.
Whats the easiest way to minimize this look?
Uneven ceiling joint/lines-dsc005692.jpg
Tenacious--M is offline   Reply With Quote
Old 06-27-2009, 04:29 PM   #2
Remodeler
MinConst's Avatar
Hard to tell the cause from the picture but it is obvously there. Could be that joist is low? Is so it you would need to fir the rest. Or too much mud was placed in that area. A long level spanning 3-4 joists prior to rocking will be your best bet.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-27-2009, 04:31 PM   #3
Thanks for the response... Can you put that in layman's terms? Lol.. this is my first home and Im very green when it comes to this stuff.... : )
Old 06-27-2009, 11:37 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
MinConst is probably right. One of your joists looks low. Those are the board that are above your ceiling. Looks like you have the same color there which is actually the best thing to hide an imperfection like that. Anything you will do to it like do two different colors or add some crown will only make it look worse. The true fix is to rip out the ceiling and fix the joist but that could be costly.
Old 06-28-2009, 09:30 PM   #5
I was afraid of that. I just want to minimize the look as much as possible. Could I basically re-mud the right side a little bit to make the line look more staight across?
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
New ceiling for uneven beams RogCat Remodeling 4 01-14-2008 05:47 AM
