Old 12-22-2012, 04:18 PM   #16
Ugh, pine sap seeping through trim paint
Shellac bonds to everything, it's the premier bonding primer
The Following User Says Thank You to jsheridan For This Useful Post:
nuclearnerd (12-22-2012)
Old 12-22-2012, 05:56 PM   #17
paper hanger and painter
chrisn's Avatar
Except, maybe, silicon caulk
Old 12-22-2012, 06:17 PM   #18
Rubbin walls since'79
Brushjockey's Avatar
Oh there ya go-- always an exception!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 12-23-2012, 06:02 AM   #19
chrisn's Avatar
but right? yes?
Old 12-23-2012, 06:46 AM   #20
BJ's going to the dark side
Old 12-26-2012, 08:55 AM   #21
It's tannin acid.
Pine does not contain tannins, like redwood and cedar do. It bleeds sap from knots in the wood. As stated previously, a shellac base coat will block this out before painting.
Will22 is offline   Reply With Quote
Old 12-26-2012, 05:00 PM   #22
Originally Posted by Will22 View Post
It's tannin acid.
Sorry Will, that's just not true. How would sap from knots discolor the whole side frame of OP's window?
All pine contains tannin. White pine contains less tannin than yellow pine. I've always known pine to be a bleed problem from tannin, and a quick google search of pine and tannin only proved it. They actually make products specifically from the tannin of pine.
mustangmike3789 (12-26-2012)
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
