Old 12-21-2012, 02:29 PM   #1
Ugh, pine sap seeping through trim paint
I redid my attic window trim with select pine, which I primed and painted with three coats of (pure) white latex. It's been about six months, and some of the boards are starting to yellow! I'm guessing it's sap from the wood making its way through the paint. Does anyone have any suggestions on how to stop the process, and return my trim to a clean white?
The windows on this old house are no longer square to the wall, so I had to do a lot of fancy carpentry to fit the trim. I'd really like to avoid suggestions that involve me redoing it (though next time I'm using MDF!)
Thanks in advance.
nuclearnerd is offline   Reply With Quote
Old 12-21-2012, 03:40 PM   #2
It's tannin acid. The only solution is to coat the affected areas with Zinsser BIN. It's an alcohol based pigmented shellac. You can get quarts of it at HD. Use a nylon bristle brush and do clean up with ammonia. It dries quickly, very quickly, so you'll have figure out how to work with it without making a mess. Good luck and check back with any questions.
The Following 3 Users Say Thank You to jsheridan For This Useful Post:
Gymschu (12-21-2012), Jay 78 (12-21-2012), nuclearnerd (12-21-2012)
Old 12-21-2012, 05:43 PM   #3
If you used Kilnz primer, there's the problum.
Old 12-21-2012, 07:00 PM   #4
Kilnz are where they fire pottery. And actually, if he used oil Kilz, he would have bought himself some more time. Oil will hold back tannin longer than latex but not as long as shellac.
cdaniels (12-27-2012), Jay 78 (12-21-2012), nuclearnerd (12-22-2012)
Old 12-21-2012, 09:50 PM   #5
Gymschu's Avatar
Kilz is actually pretty good at holding out tannin bleed from pine. Maybe not a first choice, but certainly adequate.
Old 12-22-2012, 06:17 AM   #6
paper hanger and painter
chrisn's Avatar
[quote=joecaption;1077619]If you used Kilnz primer, there's the problum.[/quote]
WRONG again as usual. Joe, please, please ,please, please, please,please ,a thousand times, please
1) Hit the spell check icon( the ABC thing in the upper right hand corner)
2) Stop posting on painting topics of which you have no knowledge
chrisn is online now   Reply With Quote
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (12-22-2012), jsheridan (12-22-2012)
Old 12-22-2012, 06:19 AM   #7
chrisn's Avatar
I have seen it bleed though many times,
BIN, never
The Following User Says Thank You to chrisn For This Useful Post:
Old 12-22-2012, 07:44 AM   #8
Rubbin walls since'79
Brushjockey's Avatar
..spell check doesn't know brand names chris...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-22-2012, 08:29 AM   #9
chrisn's Avatar
it knows problem
Old 12-22-2012, 08:46 AM   #10
Here- Kilz spelled correctly still looks like a problem...
Old 12-22-2012, 09:00 AM   #11
It would know "problum" and "exohost" fan though, just sayin.
Old 12-22-2012, 09:20 AM   #12
Hey- I'm not backing JC's speeling! ( Or mine sometimes..)
But chris has learned to use fancy letters- lol
Old 12-22-2012, 11:37 AM   #13
chrisn's Avatar
I'm lost ...............................................aga in
Old 12-22-2012, 02:36 PM   #14
Thanks for the Shellac advice. Can I apply it over the existing latex, or do I have to strip back down to bare wood?
Old 12-22-2012, 04:01 PM   #15
Over should be no problem
The Following User Says Thank You to Brushjockey For This Useful Post:
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
