Ugh...caulk Or Putty Gap Between Quarter Round And Hardwood Floor??? - Painting - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 06:35 PM   #1
Ugh...caulk or putty gap between quarter round and hardwood floor???
I was so close to being done with this pesky remodel...
My wife wanted to help me strip the masking from our newly painted trim. I showed her how to cut the line where the trim meets the floor so that the masking wouldn't tear the paint off the trim. The problem is that she got careless and cut the trim itself, leaving an uneven gap between the quarter round and the hardwood.
Now, I can't leave it like it is, and I don't want to replace it all - although I will if I have to. I'm also aware that the floor needs to expand/contract - so, the million dollar question is do I:
1) Replace the QR
2) Caulk the gap
3) Putty the gap
Anyone tried something similar?
Thanks,
Kiel
Optical1 is offline   Reply With Quote
Old 10-06-2013, 06:45 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture---there should not be a noticeable gap--the tiny gap is never caulked or filled---let's see what your looks like---Mike-----
Old 10-06-2013, 06:52 PM   #3
Well, this is probably the worst spot, but it ranges from tight to the floor to this bad...
Ugh...caulk or putty gap between quarter round and hardwood floor???-image-3598412681.jpg
Old 10-06-2013, 07:02 PM   #4
DIY staff
Damage is worse than I thought----tape the floor---caulk and paint---
P.S.---never leave your tape on long enough for the paint to dry---then you will never need to cut the paint in order to remove the tape---
Old 10-06-2013, 07:14 PM   #5
Mike,
Thanks for your input. I'll give it a go with caulking. Next time I'll pull the masking while it's still wet!!!
-Kiel
Old 10-06-2013, 07:26 PM   #6
DIY staff
That's a good idea--even if it means retaping for a second coat----
Old 10-06-2013, 09:30 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
I am thinking you might want to leave that gap. That floor is going to be expanding and contracting quite a bit and the caulk will more than likely not hold up. By all means tuck your tape in the cap and touch up the paint but I don't think anything else will really hold up.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-06-2013, 10:53 PM   #8
I'm concerned about expansion/contraction as well, but I can't live with that gap. It's either fill the gap, or replace the QR...sigh...
I guess I might as well try caulk. If it doesn't work, I'll need to replace it, which is really my only other option...
Old 10-07-2013, 01:32 AM   #9
I have used KleenEdge Brown Paper Painter Tape to take care of things like that. I slide the coated end of the paper far enough under the gap to not allow the filler to stick to the flooring or other surface. This allows the base board to move since the filler is not stuck to the floor but to the paper. If using water based filler, I use Ready Patch, make sure you don't push the paper in to far because the unsealed portion of the paper will pucker with the moisture in the filler and not give you a clean line. When the filler is dry sand prime and paint (the paper keeps paint off the floor, and use a brand new utility knife blade and carefully slice the paper along the base board when paint is dry. The paper is so thin you won't be able to see it. I have done many of these some years ago and have never had the filler crack. Caulk will always shrink when curing on something that wide and not look right.
Craig
minimiter is offline   Reply With Quote
Old 10-07-2013, 04:50 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Just quit looking at it, it's not that bad.
Old 10-07-2013, 06:17 AM   #11
ltd
Rewards Points: 536
yea really, its not that bad .maybe mask off floor and paint it you'll never know .
ltd is offline   Reply With Quote
Old 10-07-2013, 06:43 AM   #12
PoleCat's Avatar
Rewards Points: 1,652
Craig
That is the approach I used. I used some wax paper from the kitchen and joint compound. After it was shaped and touched up with paint the wax paper was wiggled loose and removed.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Painting base trim next to hardwood floor jfklein13 Painting 15 07-09-2012 09:36 AM
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
My Hardwood Floor Refinishing project roxksears General DIY Discussions 3 11-13-2009 05:43 PM
hardwood floor to carpeted step transition DIYguy2000 Carpentry 7 11-06-2009 12:09 PM
