Type Of Paint Needed For Aluminum Siding - Painting - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 06:23 PM   #1
type of paint needed for aluminum siding
Hi pro,
I have a 1969 mobile home that has aluminum exterior. Currently it has a white paint which looks kinda ugly. I am planning on repainting my exterior. Can someone please give advise such as type of paint and prime, or do I need one? should I spray paint or roll paint?
Thanks,
any tips would be appreciated
Mr.HVAC is offline   Reply With Quote
Old 09-25-2011, 08:15 AM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Aluminum siding needs to be cleaned well first. A mix of tsp and water works well, use a nylon scrub brush and a pressure washer on low pressure or hose. Only bare aluminum needs to be primed. I like to prime with Sherwin Williams DTM bonding primer. Almost any quality latex with 100% acrylic binders will work as a top coat. I usually use Sherwin Williams Superpaint on aluminum and have never had a problem. The key is cleaning well and using quality products. Spraying will give you the best result, you can roll, but I would use a low nap mohair cover, as it will give you a fairly smooth finish.
housepaintingny is offline   Reply With Quote
Old 09-25-2011, 10:43 PM   #3
thanks,
I think I am going to stick with rolling because I am afraid of paint going everywhere.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 06:52 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
Need advice on barn siding and roof paint mvonstein Painting 2 09-25-2007 08:29 PM
