Type Of Brush For Priming Trim - Painting - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 09:46 AM   #1
Type of brush for priming trim
Do you use your best brushes for priming trim that will be coated with glossy enamel, or do you feel primer will somehow ruin your best bushes and therefore use something cheaper for primer?
davej77 is offline   Reply With Quote
Old 06-07-2013, 10:14 AM   #2
Rewards Points: 13,956
Not sure how you figure primmer is going to hurt a brush.
I just use a 2-1/2 Purdy brand sash brush for all of it.
If you have a bad primmer job with brush marks, no form of finish paint is going to fix that.
Old 06-07-2013, 10:18 AM   #3
I have wondered whether primer, because it sticks so well, would be harder to thoroughly clean from a brush and would tend to clog up the upper bristles where it's difficult to clean, thus shortening the life of the brush.
However, I've been using my best brushes to get the smoothest coat of primer and have not had trouble cleaning them. Just wondered what others think about this.
Old 06-07-2013, 10:55 AM   #4
If your getting paint all the way up to the farrell your dipping the brush in to deep in the paint.
Old 06-07-2013, 03:09 PM   #5
Too Short? Cut it Again!
I tend to evolve nice brushes. I use new ones for trim paint and cutting in and as they become a little clogged and lose some flexibility I use them for primer, which is a little stickier and harder to get out of a brush.
None of mine ever get so bad some as those horrible cheap things with the coarse bristles, plastic handles, etc. I see DIYers buying. I guess they think they are so great because they are so cheap they do not have to clean them.
In general, you want to use a quality brush for primer, paint, or varnish. Expect to pay $15ish retail for a good Purdy or Wooster brush. More perhaps for natural bristle brushes for oil finishes and varnishes.
If as a homeowner, if you invest in a couple good ones for each type paint, and take care of them, they should last you near the ownership of your home if not longer. And don't fall for the packages of brushes even from the brands mentioned. I used a 2.5-3" angled sash brush most of the time.
Old 06-07-2013, 05:33 PM   #6
ltd
Rewards Points: 536
yep that's right
ltd is offline   Reply With Quote
Old 06-10-2013, 02:43 PM   #7
kimberland30's Avatar
I just cleaned all my wooster and purdy brushes over the weekend. They looked something awful - dried paint and primer on most of them. I just put them in a metal container with brush cleaner - covered it with foil and let it sit overnight. Used a wire brush the next day to get all the remaining paint out and voila...good as new.
kimberland30 is offline   Reply With Quote
Old 06-11-2013, 12:38 PM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
Mine start out for trim and final coats. Then they get downgraded to ceiling paint and primer. Then they are a dust brush.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-11-2013, 05:08 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 470
probably not, most of that stuff ruins the bristles on the brush, it might look good but it's actual life is most likely shot
Old 06-12-2013, 09:33 AM   #10
Could be, but it was better than throwing them all out and starting with new ones. I used one last night and it seemed to be fine.
Old 06-12-2013, 12:33 PM   #11
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Ive always liked those "chip" brushes, made with natural bristles for all painting, the bristles are fine and work smoothly, they have a wood handle and generally are inexpensive.
They are the best brushes I've used on smaller projects- they don't come larger than about 4"
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
Old 06-14-2013, 09:21 PM   #12
Painting Contractor CT
Rewards Points: 77
Post
Primer will not damage your brush in any way, I suggest using a quality brush even when priming.
Good Luck!
KD PAINTING is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 12:02 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 04:01 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
