Two In One No-prep Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 09:51 AM   #1
two in one no-prep paint
Does Dutch Boy Dura Weather Maxbond, no prep/no prime formula work well on chalky, kinda dirty aluminum siding, when it is not washed at all? The container says it's superior adhesion!
getterdone is offline   Reply With Quote
Old 04-26-2013, 09:57 AM   #2
Too Short? Cut it Again!
Worse Than Primer and Paint in One?
Do not fall for this marketing horse puckey! Even if it offered superior adhesion do you want your paint stuck to dirt or your siding? If there is dirt in the way, the paint cannot stick to the siding? Adhesion does not happen from the top down, unfortunately. I guess this stuff works by encapsulating dirt under a paint film? Nonsense.
Prep is an inescapable aspect of a good paint job. You are willing to spend the time painting why not a little extra time to clean the siding? And do you want your paint job, even if this could work, to look like you painted it with mud as a light colored paint mixes with the dirt you did not clean off?
I hope Ric steps in to comment on this latest fad. He suggested not long ago a company would not advertise a product clearly to appeal to a consumer market. I guess, especially with this latest hogwash, I am cynical enough to believe that even Sherwin Williams will if it will sell paint based on what the consumer thinks they want:
Paint and Primer in One
Superior One Coat Coverage
No Prep Application Over Dirty, Chalky Surfaces
Lifetime Warranty (read the fine print carefully please)
Dirt Cheap Price per Gallon
Dutch Boy Maxbond is making all the above claims and I fear lots of disappointed people soon. I guess if the company can sell enough to those who know better and do prep it will be able to afford to hand gallons of the stuff to those who will be painting over and over for eternity.
The Following User Says Thank You to user1007 For This Useful Post:
Will22 (04-26-2013)
Old 04-26-2013, 10:42 AM   #3
Rewards Points: 394
The label instructions on these product (regardless of the manufacturer) recommend proper cleaning and surface prep, in addition to priming for specific applications. There should be no language with a recommendation to skip these procedures. The fine print on Lifetime warranties provides replacement paint or a refund, nothing more.
Will22 is offline   Reply With Quote
Old 04-26-2013, 01:03 PM   #4
Rewards Points: 101
Originally Posted by getterdone View Post
does dutch boy dura weather maxbond, no prep/no prime formula work well on chalky, kinda dirty aluminum siding, when it is not washed at all? The container says it's superior adhesion!
no it does not
JMDPainting is offline   Reply With Quote
Old 04-26-2013, 04:46 PM   #5
Gymschu's Avatar
Rewards Points: 512
Even if it did, why would you want to paint over dirt and chalkiness? Hoochiemama!
Gymschu is online now   Reply With Quote
Old 04-26-2013, 09:07 PM   #6
Renovating My Land Yacht
Rewards Points: 616
Not going to get on the band wagon on paint and primer in one debate.....even if I get it I still prime. It does make a difference.
My daddy taught me the 7 P's when I was a kid and I live by them.
Proper
Prior
Preparation
Prevents
Pizz
Poor
Performance
The end result is only as good as the effort that you put into it.
Robyn
forcedreno2012 is offline   Reply With Quote
The Following 4 Users Say Thank You to forcedreno2012 For This Useful Post:
Gymschu (04-27-2013), Nailbags (04-27-2013), ToolSeeker (04-27-2013), user1007 (04-26-2013)
Old 04-26-2013, 09:12 PM   #7
This is the new enhanced bull puckey that claims you need do no prep whatsoever. I too am tired of debating the primer and paint in one. But this product's claims go further suggesting, as the OP stated, that you can go right over chalked paint or dirt! Just pop the lid and paint---one supposes ignoring the mud that forms on your brush!
Old 04-26-2013, 09:17 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
Best part is all you need for solid even application is one of these!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ddawg16 (04-26-2013)
Old 04-26-2013, 09:25 PM   #9
Actually you would need a hose for that thing to steer itself and obviously a person using the Maxbond product would not have one or they would clean the surface first.
I have posted this before but this is the best method for applying such paint.
Old 04-27-2013, 08:42 AM   #10
Rewards Points: 5,974
I also am tired of the debate. We preach and try to explain based on years of experience then someone comes along and says all-in-one is the greatest thing since sliced bread. I am to the point I think we should join the masses. When it comes up, encourage people to go buy it, buy it by the bucket. Then when they see what crap it really is and maybe start to complain the paint companies will do something about it.
A week ago got a call from a disabled vet wanted me to paint his 4 year old daughters bedroom. Said he had started it but was unable to finish. I went over and he had painted 1 wall with Olympic One so named because one coat would do it.(Yea right) Anyway this wall looked really bad. By the way we were painting a light purple over an off white. When I got done my 3 walls looked almost as bad as his 1 wall. He got all upset and wanted to know why. I told him it has to have a second coat, and he says no,no, the guy at Lowes said this would cover anything in 1 coat. I said really then why did he sell you enough to do 2 coats. Again until people start complaining its only going to get worse.
The Following 4 Users Say Thank You to ToolSeeker For This Useful Post:
cdaniels (04-28-2013), forcedreno2012 (04-27-2013), Gymschu (04-27-2013), user1007 (04-27-2013)
Old 04-27-2013, 09:00 AM   #11
Gymschu's Avatar
Rewards Points: 512
Great post, Toolseeker. So many doubt the years of experience a painter has. Hey, it would be great if it worked, our painting lives would be so much easier, but, like you, I have seen someone try it, heck, I have tried it just to be sure, and, IT DOES NOT WORK.I don't know how many times we have to shout it on here...........Paint and Primer in One DOES NOT WORK.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 04-27-2013, 09:09 AM   #12
you cannot skip prep and expect anything approaching a nice looking paint job! You cannot paint over dirt or chalk.
Old 04-27-2013, 09:13 AM   #13
kwikfishron's Avatar
Rewards Points: 218
When I started to read thread I immediately wanted to see the PDS for this product but it doesn't seem to exist (online anyway). MSDS yes, PDS no.
If anyone can find it I'd love to read it.
kwikfishron is online now   Reply With Quote
Old 04-27-2013, 10:55 AM   #14
I could not find it or a copy of the lifetime warranty online. There has to be some very strange legal clauses in 3pt type!? I did see the ad in the Menard's flyer with the exact statements the OP listed which is why I started the parallel thread prior to this one.
Absurd! Give people what they want I guess. If this stuff adheres so well I bet you cannot even get it out of the can as it wants to stick to the sides.
Sherwin Williams should put cans and buckets of this stuff on a stick. People will buy anything on a stick and pay twice as much for it.
Old 04-27-2013, 12:06 PM   #15
Rewards Points: 218
Just for fun I e-mailed Dutch and requested the PDS and warranty info.
If they respond I'll post it.
The Following User Says Thank You to kwikfishron For This Useful Post:
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Threshold prep and paint? Guido Painting 4 09-11-2008 11:08 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
